1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
11-16-2010, 10:57 AM
Jag IRS
Hello All, I am currently saving to build a ERA 289fia, I am also keep a watch for parts that I may need. I have come accross a 1987 xj6 IRS, it is still in the car. My question is what should I salvage? I will be going with the ERA design IRS. Also how would I go about determing the gearing and if it has posi, any place to look for markings or numbers? thanks Jerry
11-16-2010, 12:01 PM
wi
Cobra Make, Engine: Holliday Motorsport/396 GM / 4 speed / Jag rearend
Give me your email and i can send you a file with info on how to identify jag rears. The diff cover sometimes has a tag at one of the bolts with the ratio on it.
11-16-2010, 02:00 PM
NY
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
If you are intent upon using the ERA outboard rear, you will need the center section and, I believe, the stub axles.
The 87XJ6 is probably an open rear, ie; non-posi.
My advice is to give ERA a call and talk to Doug.
My practice has been to give them the entire rear, from flange to flange, brakes included, even when I am getting the ERA rear, inasmuch as they can use the other parts in rebuilds of other rears. I would otherwise be throwing the left over bits on the scrap pile at the recycling center.
Jim
11-16-2010, 02:43 PM
ca
Email/pm sent also.
John
11-16-2010, 04:01 PM
wi
redmt- I sent it to you. I also have assembly and dis-assembly info also in the same format.
11-16-2010, 04:47 PM
FL
Jerry et al,
Here's an article about the Jag rear in all its variations that I found very helpful some years back: http://www.firstcoastcobraclub.com/v....php?f=8&t=167
Alas, CWI is no more but the info is still viewable from my web site.
Enjoy,
Tom
11-16-2010, 06:14 PM
Cobra Make, Engine: ERA #698 428 Toploader
Are you planning to get the complete rear from E.R.A., if so you need nothing from the used rear. If you are getting the kit there is a small list of what you get and need to supply on their web site under options.
11-16-2010, 07:18 PM
ca
Fantastic info!! Thanks !! If you have anything else, I be very grateful to have it.
John
11-16-2010, 07:31 PM
wi
I will send you more tomorrow when i get to work. I have all my Cobra stuff on my external HD at work.
11-20-2010, 07:00 AM
Thanks
Thanks everyone this has been very helpfull, the wealth of information on this forum is amazing
