03-15-2011, 06:10 AM
CT
Originally Posted by WarrenG
I have the opposite situation. The red charge light never comes on. Not sure when it started, never took notice of it until somebodyelse pointed out that it didn't come on when I turned the key to the on position. I replaced the ignition switch recently is it possible that I reversed a couple of wires? Never had one of these bulbs burn out before but I suppose I should check that sometime.
The FIA is wired differently from the late 427. There is no charging warning light. If you have a drop-dash, the red light is a dummy. (and I'm not that bright either  )
