February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 10-25-2011, 10:40 AM
bliss's Avatar
Default ERA Brake Lights Dim
My brake lights work, but they are really dim and can barely be seen in sunlight.
Is there a fix for this?
Old 10-25-2011, 10:49 AM
Check this thread for a lengthy discussion on brake light upgrades. Just the new bulb is a tremendous improvement -- you don't have to go all the way with the 3rd brake light modification... even though it's a thing of beauty if I do say so myself. LED Upgrade to Rear Rectangular Lights
Old 10-25-2011, 10:59 AM
RodKnock's Avatar
"Beauty is in the eye of the beholder."
Old 10-25-2011, 11:01 AM
Uhhh, lemmeee tell you, even the snobbiest of Cobra snobs have admired the beautiful and clever craftsmanship of that third brake light. A thing of beauty, yessirreeee. Absolutely gorgeous.
Old 10-25-2011, 11:25 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
ERA?
Brakelights?
"I fear all we have done is to awaken a sleeping giant and fill him with a terrible resolve."
Go get him, Pat.
rodneym
Old 10-25-2011, 11:39 AM
bliss's Avatar
Thanks....from that tread.....
I ordered the RED 1157-R45-T bulb from LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS -- they have 45 LEDs on them and are perfect for the rectangular, single bulb, rear lights that have the light vertically installed. I had the "extra bright" bulbs in there, along with the reflectors behind them, but the LEDs make a real noticable improvement. It's a five minute installation, and the turn signals work just fine.
So, I need to order 2 RED 1157-R45-T bulbs, correct? Also, "along with the reflectors behind them" - is that another part that can be ordered? If yes, from who?
Will the bulbs simply replace the ones I have now, no alterations? (I'm not knowledgeable about this sort of thing - just a driver/owner)
Old 10-25-2011, 11:47 AM
If you have the rectangular lights, not the two round lights, they are a simple "plug and play" -- nothing to it. The reflectors are a single piece of polished aluminum that just go over back of the lights over the same bolts that you use to hold them to the body. You just use an additional two nuts to hold them on the back. Call Bob P. up and he'll send you a pair -- I'm sure it's less than $50 or so. Let me see if I can find a pic of them and I'll post them for you.
Old 10-25-2011, 11:48 AM
Murky781's Avatar
Cobra Make, Engine: ERA 781, 69' 428CJ, PPG BLACK. ERA 3005 Arctic White 331 SBF
You guys have brakes? Whhhhyyyy? If anyone is that close behind me that they need a brighter light, they better be pulling my hair and talking dirty to me! For stopping I use guard rails, bumpers and the front wall of my garage. You guys need to toughen up!
We make 3 bad decisions a day. Choose them wisely.
Old 10-25-2011, 11:54 AM
Here's a pic of the reflector. It's a very simple piece of polished aluminum, but it makes for a pretty good difference.
Old 10-25-2011, 11:59 AM
And this page, about half way down, Options list says they're $22.
Old 10-25-2011, 03:09 PM
bliss's Avatar
Thanks so much for your assistance - I'm thinkin' that I'm good to go on this.
Old 10-25-2011, 03:22 PM
Great. New LED bulbs and reflectors can both be installed in 5 minutes or less with nothing more than your thumb and forefinger. In fact, even ERAChas and RodKnock could do it, working together, after one of their benders.
Old 10-25-2011, 05:51 PM
12,937 SUBSTANTIVE posts...
Chas.
Old 10-25-2011, 05:55 PM
Would you prefer they had been procedural posts?
Old 10-25-2011, 06:33 PM
ZOERA-SC7XX's Avatar
You might have the wire plugs reversed. Try changing them.
Last edited by ZOERA-SC7XX; 10-25-2011 at 06:39 PM.. Reason: double use of the same word is a no-no
Old 10-25-2011, 06:51 PM
Quik289's Avatar
Cobra Make, Engine: ERA 2137, KC Racing 306
Ditto on reversing the wires at the taillight plug-ins. That solved my dim light problem.
Old 10-26-2011, 05:55 AM
You can check whether things are correct on the light:
Disconnect both wires from the light (making sure that the wires don't ground out).
Turn the parking lights on.
Touch the red wire to each terminal. One will light up brighter than the other. That's the terminal to correct the other wire (yellow or green).
Old 10-31-2011, 03:53 AM
Default A note to the Wise
Guys these Led light are nice but Do have problems just like HID headlights. Some bulb make alot of heat in an enclosed small area and have no outside air to swap with hot inside air. I have seen wiring harnesses, sockets, and lens melted from installing lights that are either too bright or too hot in a tail light or head light housing. Those deflectors should be a Heads UP on the amount of heat these little lights make. If wired right should be able to see them in the day light. Other note while a 3rd brake light look silly on a cobra, it might save your life or whiplash from a rearend accident. Polished Kirkhams are the oNLY car you don't have a problem not seeing any time. Rick L.
Old 10-31-2011, 05:09 AM
Originally Posted by RICK LAKE View Post
Guys these Led light are nice but Do have problems just like HID headlights. Some bulb make alot of heat in an enclosed small area...
These LEDs make absolutely no heat whatsoever.
