February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 02-12-2012, 11:10 AM
bliss's Avatar
Default Wheel Alignment Specs
Are there standard wheel alignment specs relating to ERA 427 Cobra's? I have an older ERA built in the late 80's.
I have some specs printed on a card from the seller, but I'm not sure if they are correct.
Any input - thanks.
Old 02-12-2012, 11:25 AM
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default go to their website
You might check at the ERA website...you can download the text of assembly manuals for free.
Search the thread as I think Bob Putnam has posted the specs before. You should be able to order an entire manual for your serial number car, WITH diagrams, in pdf or hard copy if you contact Bob.
As to whether they were using the late 70's/early 80's Camaro uprights in the late 80's I don't know. Bet someone weighs in this very soon...
Pete
Any input - thanks.
ERA 289 #2027
Old 02-12-2012, 11:32 AM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
Call Bob at ERA. He can give you access to the owners manual website. There are different versions of the manual for different serial number cars, so you need to download the right one for your car. However, Bob or Doug should be able to give you the specs. for your chassis number over the phone as well.
Good luck!
