November 2024
Old 04-15-2012, 11:55 AM
DanEC's Avatar
Default Question on adjust of front toe in alignment?
The manual says "Loosen the jam nut on each tie rod. Rotate the inner tie rod inside the rack boot to adjust." Seemed pretty elementary and the sleeve nut on the end of the rack assembly has flats for an open end wrench. But, when I turn it to thread forward or backward on the threaded tie rod end, the boot twists with it. I don't want to twist it around and damage the boot. I tried holding the end of the boot to see if the sleeve nut would break free and rotate inside it but it wouldn't. The boot is tight on the end of the sleeve nut. I guess cutting the zip tie strap securing the end is an option and then replace it later.
The term "inside the rack boot" isn't making sense to me unless it will turn without twisting the boot? What am I missing here - I haven't messed with many rack and pinion assemblies?
Dan
Old 04-15-2012, 12:38 PM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
cut the tie strap.
Craig
Old 04-15-2012, 01:05 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by cdnus View Post
cut the tie strap.
Craig
agreed, ......the end of the tie rod inside the boot is a ball, the rotating of it simply threads or unthreads it in the sleeve.
Fred B
Old 04-15-2012, 04:22 PM
DanEC's Avatar
Cut the zip tie - got it. Thanks for the replies.
Dan
