November 2024
Like Tree1Likes
  #21 (permalink)
Old 08-30-2014, 01:13 PM
DanEC's Avatar
Here is the new Sunbeam Specialties boot installed. You can see that it naturally rides lower.
Here is the original boot. It's thicker and more rigid and wants to sit higher.
ERA 782 Running
  #22 (permalink)
Old 08-30-2014, 05:32 PM
LMH's Avatar
LMH LMH is offline
Looks good!
Alba gu brąth
  #23 (permalink)
Old 08-31-2014, 06:14 AM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Looks great Larry, thanks. You must be very happy because I remember how pissed I used to get when my Unique did the pop out thing.
I wish I knew exactly why your shifter is so low. I love the look. It would also be more comfortable driving mine like that because between it being so high and me having to sit more forward, I am doing the Pterodactyl arm thing.
Dave
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
  #24 (permalink)
Old 08-31-2014, 11:31 AM
DanEC's Avatar
Dave
Dave - do you have the Hurst shifter and ERA lever? I can still adjust my transmission mount plate up about 1/4 inch or so. I may do so as I'm not sensing any driveline vibration so far. It won't make much difference in appearance but another 1/4" room between the ring and lever may make a bit of difference.
ERA 782 Running
  #25 (permalink)
Old 09-01-2014, 07:38 AM
I think it would make a big difference, I would do it
Yes, I have the Hurst but don't know what you mean by ERA lever?.
  #26 (permalink)
Old 09-01-2014, 09:55 AM
rub35's Avatar
Cobra Make, Engine: ERA 758 482FE
This is mine in third gear. Quite a difference. I've seen several that look like Dan's and several that look like mine. Why so different? Is it the trans or the shifter set up?
Name:  shifter photo.jpg
-Reuben F
  #27 (permalink)
Old 09-01-2014, 11:56 AM
DanEC's Avatar
My shift lever was fabricated by ERA. To make sure John sent me a tracing of a lever in stock and it matched mine perfectly. I think I will go ahead and raise the mount plate up the rest of the way. A 1/4 inch or so might make a small difference. So far with the new rubber boot I'm not having any problems. It seems to be staying locked solidly in gear when in 3rd.
Attachment 24323
That's a puzzle to me also (I assume you have a toploader and Hurst shifter). I'm wondering if there might be a couple different mount plates used over time that mount the shifter unit at different heights. I also think I remember (hope it's not a figment of my imagination) that somewhere along the line, ERA raised their transmission tunnel height a little to better fit 5 and 6 speed transmission with top mount shifters. But, our cars all seem to be fairly recent models so I would thnk the transmission tunnels would be the same.
ERA 782 Running
  #28 (permalink)
Old 09-01-2014, 12:58 PM
rub35's Avatar
Sorry if I misled Dan, mine is a T-5 modified by G-Force. I could take some under car shots if interested.
-Reuben F
  #29 (permalink)
Old 09-01-2014, 01:08 PM
rub35's Avatar
Also, shifter is a Steeda Tri-Ax with a shifter handle from Finish line p/n SH427
-Reuben F
  #30 (permalink)
Old 09-01-2014, 02:24 PM
DanEC's Avatar
Yeah - different trans and shifter would account for the difference.
ERA 782 Running
  #31 (permalink)
Old 09-02-2014, 05:19 PM
Yeah, huge difference! Well, there goes that hope out the window!!!
  #32 (permalink)
Old 09-02-2014, 08:37 PM
Cobra Make, Engine: ERA #766, FE V8, Toploader
Originally Posted by Rick Parker View Post
I read these threads from time to time regarding this subject and wonder how little tension the shifter, and sliding syncro hubs have on the newer style 5 & 6 spd transmissions such as T5, T56, etc. They all have internal shift rods, and shift smoother and easier but with the OEM Toploader or BW T10 with external shift rods and control box this it would take much more than the effort exerted by the rubber shift boot on the lever to kick it out of gear. It's really hard to comprehend how the shift boot could really be causing this??
It really does happen--when I simply unscrewed the ERA shift boot from the transmission tunnel (and left it "floating" on the gear lever), the problem went away. Reinstalling the ERA shift boot brought the problem back. Replacing the ERA shift boot with the Sunbeam Tiger shift boot solved the problem completely--no more kicking out of gear in over 1000 miles with the new boot.
I move that ERA supply the Sunbeam Tiger shift boot from now on. Any seconds?
  #33 (permalink)
Old 09-03-2014, 06:09 AM
DanEC's Avatar
I'll second - much nicer product and obviously better function. If good enough for Kirkham it should be fine for ERA.
ERA 782 Running
