March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Like Tree17Likes
  #21 (permalink)
Old 06-29-2015, 06:32 AM
S1013's Avatar
Cobra Make, Engine: ERA #3002 Slabside
Originally Posted by AndrewB View Post
Thank you everyone! I have called Peter a few times already with questions and he has been fantastic. I told my wife that I swear he was the third brother of Click and Clack. He had me laughing pretty good a few times ("Give me your wife's name as well so we know who really owns the car") -- I love it, I could talk to him for hours.
The TKO was purchased this morning from Liberty Gears complete with their upgrade kit.
S1913, vented rotors? Very interesting. Mind giving me some more info on that? I was literally just about to buy replacement rotors.
RockBit, I was quoted 11 months.
You split the Jaguar calipers, insert a spacer and build new crossover lines to accommodate the wider rotors. I had some difficulty locating the rotors as race shops were very pricey to make up custom rotors and the custom Jaguar shops like CWI are no longer around. I found a place in Australia through a Jaguar forum that sent me both the spacers and the rotors.
66 GT-350 66 Sunbeam Tiger
64 Cobra Slabside ERA
  #22 (permalink)
Old 06-29-2015, 07:33 AM
Back in 2005 or so, when I was spec'ing out my build, I am pretty sure I remember Doug chatting with me that for the FIA (and presumably now the slabside), the hydraulic TOB was the only real option. Since I was having a 427 car built, I didn't dwell on the subject. But I'll ask now, are you absolutely sure that the more recent FIAs and Slabs can now accommodate a traditional external slave and fork?
  #23 (permalink)
Old 06-29-2015, 08:34 AM
tkb289's Avatar
Good question, I am sure Bob will chime in soon.
In 2011, for ERA2136 (with QT Bell housing / Iron block 302), I went with an external setup from Mike Forte and it fit, don't know if things have changed with the newer ERAs. It was a generic kit, so I did modify the setup slightly to tweak the geometry a bit, to get it to work the way I wanted it to. The hydraulic TOB would probably be easier to install, and should be quite reliable as many production cars use them. The advantage of the external configuration is should it leak, it's a lot easier to fix than the hydraulic TOB. Just one more choice to be made when building a Cobra ...
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
  #24 (permalink)
Old 06-29-2015, 09:03 AM
WATJAG Ltd - Derek Watson - Independent Jaguar Specialist
  #25 (permalink)
Old 06-29-2015, 12:28 PM
FuzzyDiceRide's Avatar
Cobra Make, Engine: Hurricane Motorsports #1121 427W
Super ! My favorite Cobra too ! Good luck and look forward to hearing more.
  #26 (permalink)
Old 07-27-2015, 07:39 PM
Cobra Make, Engine: ERA 3012
Default Update
Just a quick update. TKO 600 was delivered (thanks again everyone), engine should be back from the machine shop any day now, and making slow progress tearing down the rear end. With these projects it'll be a fun fall/winter! Oh, this also came today:
1985 CCX likes this.
  #27 (permalink)
Old 11-06-2015, 08:41 PM
Cobra Make, Engine: ERA 2092
Default tank
where did the tank come from if you don't mind telling
  #28 (permalink)
Old 11-06-2015, 09:16 PM
LMH's Avatar
LMH LMH is offline
Hey Andrew, did that expansion tank fit on your engine? The heater hose barb looks too far back, like it might interfere with the distributer.
Alba gu brąth
  #29 (permalink)
Old 11-11-2015, 08:57 AM
Otto, the tank came from Cobra Restorers
Larry, not sure yet as the engine build will be starting in the next month or so. Hopefully things work out.
I had planned on being much further along with the engine and rear end build but things keep getting in the way. I did talk to Peter the other day on some options which has me pretty pumped!
  #30 (permalink)
Old 11-11-2015, 10:49 AM
*13*'s Avatar
The Slab wasn't available when I ordered my car. Not sure which I would have chosen if it was. Great choice of car & company! I was on the west coast when I built mine & didn't make the factory visit. I have since been & its a lot of fun to see where it all happens.
ERA FIA 2088
  #31 (permalink)
Old 11-11-2015, 10:53 AM
1985 CCX's Avatar
I too went to ERA early on, at that time there was a long wait so I went solo on the project.
  #32 (permalink)
Old 11-11-2015, 01:50 PM
*13*, I went back and forth so many times between the FIA and the slab. I still question myself every once in awhile. Just means I need to figure out how to build a second one
  #33 (permalink)
Old 11-11-2015, 02:08 PM
*13*'s Avatar
The early comp cars had flares to accommodate wider rubber. You can still have the best of both worlds
https://www.google.com/search?q=289+...Qiyb_2vAtUM%3A
ERA FIA 2088
  #34 (permalink)
Old 11-11-2015, 02:27 PM
Oh, trust me that has been considered. I've been eyeing these up on Nick's site:
Fender Spats [] - $160.00 : Acton Custom Enterprises, Custom Metal for Cobras
  #35 (permalink)
Old 11-11-2015, 02:32 PM
*13*'s Avatar
Yes, I've seen those. They would look great! So many variables with these cars. Sometimes you have to make tough style choices
ERA FIA 2088
  #36 (permalink)
Old 11-11-2015, 02:53 PM
LMH's Avatar
LMH LMH is offline
I have/had the same issue. I wanted to replicate 2142 down to the smallest detail but found that the wheels were $1100 each plus the custom made hubs to put them on the car! Leaf spring stuff is expensive anyway and you can spend huge money to get it right. Parts are much more rare too. I love the classic production small block cars anyway, so chose that route instead.
Alba gu brąth
  #37 (permalink)
Old 11-11-2015, 03:58 PM
*13*'s Avatar
You can certainly go "too far". You can also make sacrifices & have something that 999 out of a 1000 won't be able to tell apart from the original car you replicate, at a "somewhat" reasonable cost. In the end, build what you want. Thats all that matters! These cars are a lot of fun, no matter how you dice it.
ERA FIA 2088
  #38 (permalink)
Old 11-11-2015, 06:19 PM
Senile Club Cobra Member
The tank on small block is offset so the barb clears. The tank goes "fore/aft" rather than "side/side" like an FE tank does
rick@autoventureusa.net
  #39 (permalink)
Old 11-11-2015, 06:43 PM
LMH's Avatar
LMH LMH is offline
Trust me, I know the barb is offset but an original tank is different than the one from Cobra Restorers. The CR tank has the barb farther back than on an original tank.
Here's an original:
My replication:
Andrews tank may clear the distributor but it looks like it's going to be close.
Alba gu brąth
  #40 (permalink)
Old 11-12-2015, 10:48 AM
That is a total bummer. I bought that from Cobra Restorers on the premise that it was, as their website states, "Accurate as original."
