1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
7Likes
10-11-2015, 03:37 PM
AR
Very nice - that looks like it should fill the bill. What cam are you using?
10-11-2015, 04:37 PM
Cobra Make, Engine: ERA #816, 427 Side Oiler
Running a Comp Big Mutha Thumpr hydraulic roller. A lot of people give them a bad rap but I've had good luck with them. I do like hydraulic rollers...set 'em and forget 'em!
10-25-2015, 12:43 PM
CA
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
I have a 3.54 differential and a TKO with 0.82 5th gear. If you are running a big cam you gotta keep the rpm's up. Even with this set up, anything below 2,200 rpm goes to a down shift.
Drink no wine before its time
02-16-2016, 11:43 AM
NY
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
According to Peter, they have a year's worth of orders on the books. So, if you are on the fence, jump into the queue.
As an aside, my ERA289 with a 302 has 3.77 gears and the long .64 5th. My ERAFIA has a bored and stocked 302 with 3:31 rear and .82 5th.
02-16-2016, 12:24 PM
Originally Posted by RockBit
Yes. I have ordered an ERA 427 SC and expect delivery in late March of 2016. It was ordered as a roller and will be painted in Connecticut. Lykins Motorsports is building the engine for it, and will also supply the transmission, clutch, etc. It is a long wait but I'm sure it will be worth it!
... and how is this build progressing?
02-16-2016, 01:30 PM
OH
Cobra Make, Engine: ERA 714
I was just in ERA's shops about 3 weeks back and snapped a few photos...
Phil
TX
Cobra Make, Engine: ERA #812 427/482 FE
It's going slower than I expected. The chassis is plumbed with brake lines, and the inner panels are mounted on the body. Some of the aluminum panels are going on the chassis. I asked Peter when it would go to the painter but he didn't tell me. I think I am currently looking at delivery in June but don't really know. Brent is waiting to assemble the engine until we get a little closer to Dday.
Chris
02-16-2016, 01:31 PM
OH
Another pic
Pic 2
02-16-2016, 01:34 PM
OH
Pete's engine
Pic 3 from the beautiful black ERA Cobra.
02-16-2016, 02:35 PM
I assume that the GT40 replicas were in the queue prior to ERA ceasing production of them?
02-16-2016, 03:24 PM
NY
ERA is finishing up the remaining GTs, all of which I understand are spoken for. They have decided not to do any more for a number of reasons, so, if you want one you will have to look for a "pre-owned ERA" or look to the competition.
Obviously you don't know about the "secret queue."
02-16-2016, 03:32 PM
NY
Peter built the "cammer" car a decade or so ago. Fitting that SOC lump under the hood and into the frame necessitated a number of modifications. With the gear and chain cam drive, the first thing you hear coming down the street is the whine before the thunder. (Sounds like a lead in to a joke about Miami.)
Standard 427 or 428 for that matter is more usable on the street, but open the hood and there is nothing else quite like it.
02-16-2016, 04:10 PM
If there is an ERA "secret queue," then folks like me with Oliver Twist-like net worth's wouldn't qualify.
02-16-2016, 04:18 PM
NY
To quote Peter, "For anyone who can write a check, where's the challenge?" "If you can't write a check and find a way to do it, that's something spectacular."
02-16-2016, 05:29 PM
OH
I understood the golf one and the silver one were in for minor work. The red one was being finished before being shipped to France. I drooled over all of them including Peter's cammer. It did fit very tight but looked like it belonged there. The ERA guys are all great.
Phil
02-16-2016, 05:53 PM
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
To the OP you want to get with Brent of the gearing. This will have a cam in it. That cam will not like low rpm. How low is low is the question and Brent will know.
My only other suggestion is the speedo. I would get the electronically driven speedo. It is driven by the speed sensor that comes with the TKO. The cable drive unit is a POS. If you are going for authentic this might be an issue but I thought I would throw it out there for what it is worth.
Good luck!
Bill
02-18-2016, 11:22 AM
VA
Cobra Make, Engine: ERA Slabside 3013, 351W
Just ordered a Slabside for delivery in about 12 months, 12 agonizing, painfully long months. It will be a street cruiser.
I could use some feed back on drivetrain, currently thinking: 302-350/TKO600-.64:1/3.31:1 rear dif. I was originally thinking 380 to 400 hp but at ~ 2300 lbs that is a lot of power for a street machine.
If anyone has built one I would like to hear about engine builders, recommendations, issues, things you learned as you went...etc
Many thanks
02-18-2016, 11:32 AM
NY
My wife and I own and enjoy the first ERA slabside. I will try to post some pictures later.
With a 3:31 rear you want the .82 fifth gear (See earlier post)
Jim
02-18-2016, 11:38 AM
OR
Many thanks
I'm running about 350+ hp with big, wide sticky tires & it's pretty manageable. You'll get a lot of varying replies. You'll have a lot less tire on the ground with a slab. I personally think 380 would be a lot, if you aren't cautious behind the wheel.
ERA FIA 2088
