April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 09-29-2017, 05:19 PM
Karl Bebout's Avatar
Default ERA Stub Axle Info Needed....PLEASE
My 2119 and I were on a nice 4000 mile road trip, having a great time, loving life. UNTIL, just as I pulled off the Interstate for fuel, my rear end locked up. Seems I lost the pinion seal, then the lube, then the pinion bearing, then the posi...Real lucky it didn't happen a couple minutes earlier at 85MPH. Found a good repair shop in Boise and they've been sorting and searching several days. Last night, it was discovered that in addition to all the other damage, my axle stubs had twisted. We have all the other parts needed, I hope, but now to source the stub axles. I have the standard Jag/Salisbury set up with the inboard brakes. Are the stub axles custom made or are they from a specific model. 19 spline BTW. Any info is greatly appreciated.
Karlos
Old 09-29-2017, 05:31 PM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
Call Bob Putnam at ERA 860 224-0253. He probably has documentation of your build, and may have replacement parts. I think they are there on Saturday mornings too.
Old 09-29-2017, 05:41 PM
Pete's right -- ERA has (or they used to) both regular, and high-strength, stub axles in stock. I would call them first. I have the outboard braked rear, not the standard, but it uses the same Jaguar stub axles.
Old 09-29-2017, 05:52 PM
PeteF's Avatar
Bob has also shipped me parts quickly, when I needed them.
Old 09-29-2017, 08:31 PM
I'll be calling ERA in the morning. Thanks
Karlos
Old 09-30-2017, 06:12 AM
The differential (and stub axles) is based on a 1965-1987 Jaguar XJ and the corresponding XKE years. See the manual.
Old 09-30-2017, 06:42 AM
Thanks everyone. The search continues, but now I know better exactly what I'm looking for.
Karlos
Old 09-30-2017, 09:36 AM
EM-0785's Avatar
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Here are some possible options? I recently did some initial research on resources for Jag IRS rebuilds/upgrades/parts (incl strong axles), Seems the 19 splines are getting harder to find. Some below offer more 30 spline conversions, but may be good resources for locating 19 splined? Don’t know if all are still in business, mean no disrespect if they aren’t around. Hopefully this can help (in no particular order):
Coventry West Inc. (Jag parts, rebuilds, Georgia, 8-5 M-F ET)
800-331-2193; 770-484-6500
Mark Williams Enterprises (Axles, driveshafts, etc., Colorado, 8-5 M-F Mountain)
866-508-6394; 303-665-6901
JH Engineering (Jag/IRS parts & engineering, California)
760-228-0241; 402-430-9178 (cell) ; jhengineering.com
Maurice Weaver at Unique Motorcars
They still use Jag IRS and may be a valuable resource
256-546-3708
AJS Engineering Services (Alan Slawson) – Jag IRS Rebuilds
Tel: 07831 163 158
Email: sales@ajsengineering.com
Vintage Jag Works - Idaho
Ward Engineering – ward-engineering.co.uk (parts & rebuilds, in U.K.)
Jagaxles.co.uk (parts)
Jagbits.com (parts, not XKE?)
Classicjaguar.com (indicates more E type jag IRS rebuilds than anyone else in the U.S.)
Lippincotts Garage – jag IRS rebuilds, Pennsylvania
ERA
Kirkham
4 wheel drive shops
Yukon Gear (axles, driveshafts)
XJ’s Unlimited (parts, xjs.com)
Moss Motors (parts, mossmotors.com)
For what it's worth...Brent
Old 09-30-2017, 09:28 PM
Brent, thank you for the list. We'd tried a few of them and now there are more to contact, if necessary. I talked to Bob Putnam this morning and I'll be calling back on Monday morning to talk to their parts guru, Doug.
Karlos
Old 10-01-2017, 12:31 AM
EM-0785's Avatar
Hi Karl,
I imagine you may be in a timeframe to get back in action given the circumstance on your trip. So perhaps you need to find whatever you can that’s readily available.
However, it also sounds like stronger material/treatment axles are in order if the existing ones twisted on your car already.
You may be aware, but it seems many are using 4340 chrome-moly or 1541(H) alloy steel axles. Those seem to be common aftermarket stub axles in blogs and on Summit for example (just in terms of surveying materials).
Obviously, some bloggers recommend higher quality variants with various heat treatment and other properties. This seems to include 4340M (I believe the same as 300M) fairly commonly, some E4340, some 4340AQ (aircraft quality), some 9310, etc.
At any rate, it may just be a good discussion point/topic with Bob Putnam or such as you work to narrow your search.
I have a couple charts that list some relative axle material strength information for general perspective, but I can't seem to attach them. If I get a chance soon and can get it figured, I'll do so.
Wish you the best there! Please do update with your source/results for those of us that will likely be doing similar at some point.
Brent
Old 10-01-2017, 07:02 AM
joyridin''s Avatar
This is probably what you need:
https://www.bighealey.co.uk/jaguar/axle-5?page=2
They make the 19 spline axles for their race cars.
I do not know what engine you have, but if you have to have new axles made, you might want to think about going to a 30 spline and save yourself a lot of grief later. I upgraded mine over the winter last year. You can do it 2 ways. 1) replace the carrier, or 2) you can replace the internals of the carrier with 30 spline gears and use the 30 spline axles. Either way, it will be a lot stronger.
If you are in a real hurry, I have a set sitting here from a 65 Jag that had tapered bearings if that is the style you have.
Old 10-01-2017, 09:11 AM
Joyridin', sent PM.
Regrettably, my puny little 289 doesn't have the torque to twist the axles. It must have happened when the differential locked up, and the tires kept trying to turn.
Thanks y'all
Karlos
Old 10-03-2017, 08:28 PM
Axle stubs are in transit to my repair shop in Boise and should be there either tomorrow or Thursday. Joyridin Ron in Cleveland was a tremendous help. He knew I was in a bind but didn't rape me on the price, was very reasonable and did everything he could to get the parts moving quickly. After Ron and I got everything arranged, I received a reply from Jaguar Heaven's Don, that they had both the early style(ball bearing) and later style (tapered bearing) in stock, should anyone else have the need. Thanks for all the help and suggestions.
Karlos
Old 10-04-2017, 03:18 AM
1795's Avatar
Karl,
Nice to hear that you will soon be back on your way. It was also nice to see the cobra community coming forward and helping in a time of need. I hope that your 289 did not notice that "puny" remark, he might feel the need to set you straight by tearing through those new stub axles in a hurry
Jim
