February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree4Likes
  #21 (permalink)
Old 08-29-2018, 02:45 PM
Originally Posted by my427cobra View Post
Hi classical glass. It has been often said by forum members and stated in pad instructions to "roughen the pads and rotors".
But I have yet to see specific instructions on how to do it.
Roughen by hand or by mechanical means (like a sanding disc on an sir tool)?
Grit of the abrasive used?
Cleaning instructions (Brakekleen or thinners)?
This info would be helpful.
Greg
I used 80 grit on a 2" sanding disk on a right angle air grinder. Lightly run the disk over the rotors as you spin them, sand the inner and outer side of the rotor. Be extra carful not to gouge the surface of the rotors. I always use "Brake Clean" (green label) to wash and clean all brake parts.It's really not that difficult, just take your time. Good luck.....
  #22 (permalink)
Old 08-30-2018, 07:34 AM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
When I did my back inboard brakes I used 80 grit on a sanding block,. I would not use a sanding disc! The block insures you will not gouge the rotor. It was a ton of work and very awkward to do. If there was more room to work I would say a palm held DA might work pretty good.
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
  #23 (permalink)
Old 08-30-2018, 10:36 AM
Club Cobra Member
Cobra Make, Engine: NAF 427
Thanks for the tips guys.
Greg
  #24 (permalink)
Old 08-30-2018, 12:21 PM
cobra 53's Avatar
Cobra Make, Engine: NAF 289 Blue/White strips
to Classical glass
what size of Master cylinders did you install?
Rico, NAF 289
  #25 (permalink)
Old 08-31-2018, 11:38 AM
Originally Posted by cobra 53 View Post
to Classical glass
.875 front (7/8")
.750 rear (3/4")
That's originally came with the car.
  #26 (permalink)
Old 09-05-2018, 10:26 AM
Cobra Make, Engine: ERA, stroked 428FE (462ci)
I have Wilwood calipers with the BP10 pad material and the brakes lack initial bite and overall stopping power. I'm interested in changing to a different pad material to see if I get improved brake performance.
Does anyone have experience of changing from Wilwood BP10 to say Hawk HPS?
  #27 (permalink)
Old 09-05-2018, 02:57 PM
As I've written before, I have the big Sierras, not Wilwood. But one of the reasons I went with the Hawk pads I referenced was that my existing "soft" Sierra racing pads sounded like a garbage truck at certain times, usually when I was easing down a hill or coming to a stoplight. A fellow ERA owner told me that not only did the Hawks increase non-racing stopping power, but that they eliminated the squeal and groan. I can truthfully say that, since I installed the Hawks, I have not heard a single squeal or groan from them. And, I did not use the shims nor did I use any anti-squeal goo. I just pulled out the old pads and stuffed in the new ones.
rads42 likes this.
