Old 12-30-2018, 08:27 PM
Cobra Make, Engine: ERA 2092
Default fresh air vent cables
my pass side cable is frozen and needs replacing. I have been reading that the cable style has changed over the years and mine is a 2004 vintage where the inner cable wraps around the lever for the valve . any help would be great
Old 12-31-2018, 05:24 AM
DanEC's Avatar
The easiest way to replace it is to call John at ERA and have them send you a new one (in exchange for a few $). If really frozen the first thing I would do is remove it and get some Sil Glyde and try getting it to moving again to re-use. You can buy it on Amazon as well as NAPA.
https://encrypted-tbn1.gstatic.com/s...N-nPA&usqp=CAc
ERA 782 Running
Old 12-31-2018, 05:49 AM
Cobra Make, Engine: ERA#375, FE 428, 1966 block, built by Jim Coleman Racing Engines, Stratford, CT
Otto:
Sorry to hear your cable is frozen. However, to replace it you will have to remove the entire cable. Since that is a fact, I would remove the frozen cable and as DanEC says, begin work on it to see if lubricant will remedy the situation. It is not a very hard operation but is a bit fiddly.
Good Luck.
ERA 375 - former Clubcobra ID REDSC400
TESLA P90D is my daily driver
