March 2025
30 31
Like Tree2Likes
  • 1 Post By Grubby
  • 1 Post By patrickt
Old 05-10-2021, 03:57 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Holley Fuel Pump 12-125
Well, my original fuel pump (SW 82052) died about 1/2 mile from the house. Able to get home by pouring fuel down the fuel bowl vents a few times. The old pump is not available from SW. Their replacement pump, SW 82091, does 43 GPH and 8 PSI.
Several years ago, expecting this event, I purchased a Holley 12-125 pump, 125 GPH and 7 PSI. Its supposedly quiet since it is a geo-rotor pump.
Here's my question, switch pump would be better? Or perhaps another pump?? The Holley pump is heavy and will have to be mounted (with nut inserts) to the frame behind the left rear wheel. Not particular easy given the 6 inches available to drill, etc. If I purchased the new SW pump, it looks lighter like the original and could be mounted to a vertical fiberglass truck panel like the old.
The car is ERA454, 425 HP, 650 DP carb. Thoughts please.
Old 05-10-2021, 05:05 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
That is a pretty big pump for your power level. If you want to stay that big the Holley SNIPER DIECAST 340 LPH IN-TANK CARBURETED RETROFIT FUEL MODULE RETURNLESS SYSTEM looks like a clean installation.
A guy on the ERA board on this site, put one in his build. No return line or pressure regulator needed.
It is the one I am planning for my ERA build. It will fit in the tank, directly in front of the existing sending unit. It is quiet since it is in the tank.
Nice clean installation with a fuel line running the normal ERA path from tank to carb.
eschaider likes this.
Old 05-10-2021, 11:02 PM
eschaider's Avatar
+1^
This is a great solution and the in tank location will also extend the life of the pump by being immersed in cooling fuel most of the time, just like the OEM EFI pumps.
Ed
Old 05-11-2021, 02:52 AM
Sounds like a great in-tank solution. I believe Holley also offers a electric fuel level pod that eliminates the old style float and lever assembly. In the ERA I am concerned about the space between the top of the tank and the truck floor. I beleive it is only 1/4 inch.
Any other thoughts about the 12-125 pump or another external fuel pump?
Old 05-11-2021, 02:02 PM
kitcarbp's Avatar
Default Edelbrock
In tanks are the best solution these days imo. If you want to keep with an external pump, im using this Edelbrock pump. Its high quality and a little quieter than most and has an internal regulator that is adjustable! Its set at 6.5 psi for their carbs but Im able to adjust it from 5-8 psi in my experience. Im running an Edelbrock carb with it. I have a new build with 800 ish miles and its a great pump so far. Edelbrock also sell a service kit for the pump when its time to replace or clean the internal stainless screen. Its a well designed pump and even though Ive only got 800 miles on it. its nearly 13 years old
https://www.edelbrock.com/quiet-flo-...-gph-1791.html
Old 05-11-2021, 02:14 PM
... or just bolt on an old Carter mechanical pump.
ERA 626 likes this.
Old 05-11-2021, 07:07 PM
I would like to run a mechanical pump but my timing cover is for an EFI set up. Right now looking for the best external electric pump solution. After retirement, I will drop the tank and fit an in-tank pump.
