December 2024
Like Tree4Likes
Old 05-15-2021, 02:59 PM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
Default Battery Disconnect Switch
Hey all, I need some help. I tried to start my car this morning and got nothing. I checked the battery voltage at 12.74V, and I keep a battery tender on it. This is a newish Optima red top. I’m confident the battery is good.
I have the trunk mounted battery set up. Next to the battery is a disconnect switch, which has the positive battery cable attached, From the other side of the switch the cable goes to the starter.
I checked voltage at the cable on the starter and get about half a volt. The only thing in between is the disconnect switch.
Is it possible the disconnect switch has gone bad? I use it quite a bit but have never had an issue before.
Chris
Old 05-15-2021, 03:29 PM
twobjshelbys's Avatar
Did you just bypass the disconnect switch?
Tony
CSX4005LA
Old 05-15-2021, 04:15 PM
Is it a simple, moron-proof switch like mine? Or is it fancy and complicated....
Old 05-15-2021, 04:33 PM
RockBit's Avatar
I bypassed the switch and everything came to life. It is hard to get to, and the old man paper thin skin on my arm is Now bruised and bleeding.
It is the disconnect that ERA installed with a key. I guess I’ll talk to Peter P. On Monday to get a new one, unless someone has a better suggestion/brand.
I never thought a simple part like this would fail.
Grubby likes this.
Chris
Old 05-15-2021, 04:59 PM
Summit Racing has dozens of battery disconnect switches, most sound like the style you have. https://www.summitracing.com/search/...nnect-switches Now, considering I don't have a trunk mounted battery, and you can see my simple knife switch above, others will have better input. But I do like a switch where I never have to guess if it's open or closed.
Old 05-15-2021, 06:07 PM
Surprised at you guys, especially Patrick. Disconnects should always be on the battery ground cable. Drag, road race, Nascar.
ERA 626 likes this.
Old 05-15-2021, 06:29 PM
I have one on the negative side too.
Old 05-16-2021, 07:08 AM
DanEC's Avatar
If it’s one of those green knob disconnects, some of them do go bad over time and loose continuity when engaged. Others I’ve had have worked well. So quality is sort of hit or miss. The knife type like in Patrick’s picture are pretty much dead reliable.
ERA 782 Running
Old 05-16-2021, 10:08 AM
Cobra Make, Engine: Kirkham #259
And dangerous as well.....any time you have a large open switch like that you need a cover to prevent an accid3nt.....that could never pass a Trans Am or SCCA tech inspection....
ERA 626 likes this.
Morris
Old 05-16-2021, 10:34 AM
Cobra Make, Engine: SPF832, 466cid
Or military, medical device.
Old 05-16-2021, 10:38 AM
Naaah, you just slip the inspector a couple of C-Notes and you're good to go.
Old 05-23-2021, 09:28 AM
I've had two of the "green knob" go bad. They refuse to provide the proper ground and make it look like a bad battery. And yes, these should be between the negative terminal and ground earth. NEVER put on the hot side.
Old 05-23-2021, 10:07 AM
OK, how do I reconcile that with the NHRA rules? Uhhh, like this one:
Old 05-23-2021, 10:38 AM
I would read up on those rules again. I just checked Nascar, SCCA, NASA, NHRA and all say positive. I did come across a kid on a Bemmer site that said negative so there's that.
Old 05-23-2021, 10:49 AM
What?!? You're double checking my cites on me?
Old 05-23-2021, 11:08 AM
I would assume the 58-67 VW 6vdc positive ground cars would have a negative cutoff switch.
1795 likes this.
Old 05-23-2021, 11:33 AM
1795's Avatar
My race car is set to SCCA and Vintage racing standards, and yes the kill switch is to the positive terminal.
Old 05-23-2021, 11:39 AM
... Vintage racing standards
Well what could be more vintage than dropping a spanner on an open-air cutoff knife switch that is mounted inches away from a grounded aluminum firewall?
Old 05-23-2021, 12:10 PM
If you disconnect the negative cable... you will not shut off the motor.....because the alternator will use its chassis to have a ground and keep the motor running....
That is why the a Sanction bodies want the positive side disconnected so that you kill the power coming from the Battery and on those disconnect switches is a smaller set of contacts that disconnect the power to the alternator so the motor shuts off.
That’s the first thing they check when you go to the tech shed....
Morris
Old 05-23-2021, 02:39 PM
1795's Avatar
As Morris states, if you do not wire the battery disconnect with correctly, when you engage the kill switch on a running engine, it will keep running. The first time that I wired the kill switch I tested it on a non-running engine and the engine wouldn't start and I thought that I had done it right. Then when the SCCA tech session came and I had to use the battery disconnect to stop a running engine it did not, as the alternator kept the engine running. Back to the paddock and time to re-wire. Not making that mistake again.
Jim
