March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 05-15-2003, 02:30 PM
Default Upper radiator hose replacement
I built ERA 469 about 5 years ago, and used the recommended Gates 20552 hose, which was readily available at the time. Now, it is not listed anywhere that I can find, and there is no service replacement listed. Is there a replacement, or is this a part number that was originally designed for an OEM application that I can look up? Any recent builders out there find a replacement?
Thanks.
Old 05-16-2003, 05:01 AM
The latest hose replacement is Gates 20819. That's what happens when you've been building essentially the same car for over 20 years. The replacement parts that were once easy to get have been phased out...
But not us.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 07-10-2018, 06:21 PM
Cobra Make, Engine: ERA 427sc
I just bought a 20819 to replace an existing 20552 which is starting to crack. The new hose is quite a bit wider and the end that connects to the radiator isn't long enough to clear the support bars. Is there a better part to use these days?
Edit: Actually it fits just fine if you bend it around the corner with the spring inside to keep it from collapsing. Hopefully being up against the frame is okay and doesn't rub too much due to vibrations.
Old 07-11-2018, 06:40 AM
Cobra Make, Engine: ERA 714
I just changed mine last night. The replacement for Gates hoses did not work so I pulled the two short hoses and went to the auto parts store and matched them to two different hoses and then cut the pieces to fit for my FE. My old hoses were actually weeping through. I will start up tonight and make sure I have no leaks.
Phil
Old 07-11-2018, 05:57 PM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Thanks.
Is this a typo on car number or year built. My car is 698 built in 2004?
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
Old 07-11-2018, 06:13 PM
bcrumpley's Avatar
Cobra Make, Engine: ERA #828
Radiator hoses: Spefications and interchanges
It takes a different hose depending on whether or not you have the rigid connecting pipe.
Old 07-12-2018, 04:06 AM
xb-60's Avatar
Cheesepocket posted in 2003....
Old 07-12-2018, 04:37 AM
Cobra Make, Engine: '65 Shelby Cobra, '66 Shelby GT350's
You might want to opt for siicone equivalent sizes rather than rubber, higher heat tolerance and far more durable.
~ Steven
6S1806, 1966 Shelby GT350 B/P Race car.
6S246, Shelby GT350 "carryover"
6S1745 Shelby GT350
Old 07-13-2018, 07:50 PM
ooops
Old 07-14-2018, 05:25 AM
Default Silicone hose replacement
I recently replaced all my hoses with silicone hoses from HPS. The quality of the hoses are great and come in a few colors, if your interested.
Display Modes
