January 2025
26 27 28 29 30 31
Old 05-22-2005, 06:02 PM
Cobra Make, Engine: ERA 390 Stroked to 418
Question Brake lights and right rear turn signal died.
Went for a quick ride the other night,when I drove in my wife noticed both brake lights didn't work,When I checked further the right rear turn signal also didn't work .Anybody have any Ideas before I start taking it apart?Thanks.
Old 05-22-2005, 09:09 PM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
Sounds like a bad ground
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 05-23-2005, 04:53 AM
See this page for troubleshooting the rear lights.
Old 05-29-2005, 08:36 AM
Update,I replaced the trailor adapter,as per trouble shooting guide, now everything works except now the brake lights are on all the time when ignition switch is on.They stay on even if you take the wires off the brake switch.The pink wire under dash is alive all the time when ig. switch is on.Any clues what's wrong now?Thanks
Old 05-29-2005, 06:23 PM
Cobra Make, Engine: Concept, Boss351
Send a message via Yahoo to oldmachdriver
mine was doing that , ended up being the pedal wasnt comming back all the way up to contact the brakelight switch....on my car the brake pedal arm has to come up and contact the switch to shut it off...little bit of lube on the pedal assembly took care of that. hope yours is that easy....
Ne Desit Virtus
"Let Valor Not Fail"
Old 05-29-2005, 07:29 PM
Not that easy on my ERA,They use an elec switch on the master cyl.I don't think the problem is there ,because if I disconnect the switch the lights are stiil on.I'm thinking maybe a bad relay.I'm still tring to figure out where the elec. comes from to power the brake lights.Thanks anyway.
Old 05-30-2005, 04:56 AM
If the wires are disconnected from the brake light switch, the pink wire should be dead even if the brake switch is defective. Furthermore, the brake circuit power is dependant on the ignition switch being on.
I suspect that the "real" pink wire may be hiding elsewhere.
Old 05-30-2005, 07:35 PM
Update ,I stand corrected,if you take the pink off the brake switch it's live all the time that the Ign. is on,thus the brake lites are on all the time.Can the pink get power from the turn signal switch if it is bad?
Old 05-31-2005, 05:06 AM
If the pink wire at the brake light switch is still live even when disconnected from the switch, it must be getting feedback from the trailer relay somehow.
Your trailer relay is designed for a 3-wire car to a 2-wire trailer, right?
Old 05-31-2005, 08:37 PM
I ,ran a new wire to replace the pink,from the brake switch to the trailor adapter,all seems to work now.Thanks for all your help.
