January 2025
26 27 28 29 30 31
Old 04-13-2006, 09:25 PM
Default ? about Jag rear
The manual list the following years for the jag rear assembly, '64-74 XKE Series 1 and 2, and '65-87 xj6.
Is that truly the only years for the rear that you can use or is it more broad than that?
Thanks
SM
Old 04-13-2006, 10:44 PM
Never mind, just reading throught the threads and see that any inboard brake jag rear will work .
Old 04-14-2006, 07:55 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
You do want to try and find one with limited slip. Open rears can be converted, but there is an obvious expense in doing so.
J
Old 04-14-2006, 09:04 AM
Not being familiar with jags, how would I know one with limited slip when I see it?
Old 04-14-2006, 09:14 AM
External markings on the differential back cover are not reliable. The best way to check is the standard "turn one axle while holding the other" method.
Old 04-14-2006, 09:16 AM
got it, thanks
Scott
Old 04-14-2006, 09:22 AM
Eljaro's Avatar
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
usually thre is a tag or marking on the back of the housing with "PL", for PowerLock
Nothing sounds better than a Cobra in a Tunnel !
Old 04-15-2006, 05:04 AM
ZOERA-SC7XX's Avatar
If you get one from an XJS it'll be a posi rear, either 3.08 or 3.31.
