December 2024
Old 02-05-2007, 12:11 AM
Cobra Make, Engine: None...yet
Default Oxygen Sensor
I've been reading threads about O2 sensors for EFI systems. I was wondering if anyone has put an O2 sensor on their ERA? I plan to run sidepipes and not the undercar exhaust. I'd really like to see some pictures of where you put it and how you were able to hide it.
Thanks in advance,
Mike
Old 02-05-2007, 07:48 AM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default EZ to install
I just put O2 sensors in my exhaust, there is plenty of room, just intall your pipes and then mark a place that works for your car. Its just a wire with a small sensor, ez to place and hide if you want to. You should keep the sensor somewhat close to the engine, I am sure the distance range is in the instructions if you are using an aftermarket setup.
Old 02-05-2007, 08:00 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
And keep it between 3:00 or 9:00 on the top side 6 to 12" from a Radius..
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
Old 02-05-2007, 08:02 AM
Cobra Make, Engine: Exact427
Default O2 Sensor Placement for carb setup
I have seen these placed in the collector portion of the side pipe, about the middle of the 6" section where all 4 pipes dump. The Bung was welded about 25 degrees down on the inside. There is a small sweet spot where the sensor will clear the body and not be lower than the side pipe. This same spot is all but invisible from all angles of view. Very easy to wire and install/remove the sensor.
As I recall the sensor is speced for a certain distance from the exhaust port (24" - 30"??), but you need a point where all 4 cylinders merge and this is the first location.
The O2 sensors can inserted and connected to an "in the cockpit" gauge for tuning the carb(s) primary and secondary circuits. Unless you change something, the sensors can then be removed.
Haven't tried this approach, but laying two digital voltmeters in the right seat, each connected to a sensor might work. Post results if someone tries this as it seems ideal for a temporary installation.
