January 2025
26 27 28 29 30 31
Old 06-13-2007, 07:26 AM
Default ERA Lube Question
Bob,are the front drive shaft U-Joint and Slip Yoke greaseable from beneath the car? And are there any lube points on the ERA outboard-brake rear besides the U-Joints?
Old 06-13-2007, 08:07 AM
Both the driveshaft U joints are reachable from underneath the car but you'll need a gun with a narrow neck. Those and the half-shafts are the only rear fittings. It couldn't hurt to squirt a little grease on the bottom rose joint on the front and rear shocks though.
Old 06-13-2007, 08:09 AM
Originally Posted by strictlypersonl
Both the driveshaft U joints are reachable from underneath the car...
and the slip yoke as well?
Old 06-13-2007, 08:15 AM
IIRC, the slip yoke gets its lube from the transmission oil. It doesn't get anything external.
Old 06-13-2007, 08:17 AM
Well that makes it easy. Thanks.
