1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
07-07-2009, 04:47 PM
KY
Now that's funny.
Considering that TKOs don't come with the shifter handle already bolted to them, I would call this a user error.
07-07-2009, 05:09 PM
FL
Cobra Make, Engine: Kirkham #570 w Shelby FE
Originally Posted by ng8264723
Jeez the Kirkham has a quality shifter that comes with the car for a tremec. Too bad ERA doesn't. It's funny that FFR has a quality shifter as well
hmmmmmmmmmmmmmmmmm
Well, doesn't come with the car, but they do have one.
Patrick, get rid of that backward Mustang shifter Jerry-rig and relocate the shifter to the correct location. (not to be confused with the "original" location)
If you'd keep a coat hanger in your tool kit (like your supposed to, along with duct tape and epoxy putty) you'd have been able to get this fixed in a jiffy.
If all else fails the passenger harness also serves as a tow harness (passenger=propulsion), although you need to make sure the cattle prod has fresh batteries.
07-07-2009, 05:33 PM
The Shifter Is Actually Pretty Nice...
Someone put some thought, albeit no LocTite, in to the ERA shifter. I'm not sure if you can see it in this photo but it actually angles to the left a bit. In this shot the shaft is directly vertical and "flat" as it would be up against the Tremec linkage. It's quite comfortable and the welds appear to be quite stout. I doubt I'll have any more problems with it. Be that as it may, please feel free to continue piling on, although for the life of me I'm not sure why....
07-07-2009, 05:52 PM
Along with the vibration that comes naturally to these cars, you are also working the shifter A COUPLE HUNDRED TIMES A DAY just going for a putt.
This has also happened to me once.
Of course it's REAL! You are NOT imagining it!
We don't want a bigger government; We want a government that does a few BIG things, and does them right.
If you think that you can cut it, if you think you got the time, they'll only give you one chance, better get it right first time. 'Cause in this game you're playin, if you lose you got to pay. And if you make just ONE wrong move, you'll get BLOWN AWAY!
07-07-2009, 06:04 PM
You just let the cat out of the bag
07-07-2009, 06:20 PM
Originally Posted by RICK LAKE
All the signs of the easy life. Are you sure you know how to work on that car?????:confused
Yes, but I borrow Jamo's butler to do all the heavy lifting....
07-07-2009, 07:33 PM
FL
You really didn't think you'd get a break did you? Wait till the rest of the FF guys read this thread.
07-07-2009, 07:49 PM
What makes you think they can read?
07-07-2009, 10:53 PM
What a difference a night makes. House guests must be gone.
07-08-2009, 06:17 AM
Member of the north
Cobra Make, Engine: A Cobra
Use that blue stuff. The red will cause heart aches.
I have this exact thing happend two years ago. On the freeway and lost all but third. Stuck a screwdriver through the bolt hole to drive home.
Glad you didn't have worse problems!
07-09-2009, 07:55 PM
OR
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Welcome to the club. Happened to me about half way through an 800 mile trip. Up side was the screw/bolt was still under the boot so I could just put it back in. Lots of blue locktite since then whenever I take the bolts out.
DonC
05-06-2010, 06:35 PM
FL
Cobra Make, Engine: ERA 427 - #783
I'm resurrecting an old thread, since this happened to me today, but because I had read this thread a while ago I knew that my shifter was loosening before it completely went out. Once I felt a little sloppiness in the shifts and a wiggle in the shift handle, I knew exactly what it was. A quick stop at the side of the road, a lift of the boot, and a tightening of the bolts on the shifter cured my ills. Once I got home, blue loctite sealed the deal.
It's nice to anticipate problems, because of this forum, before they get full grown.
Thanks guys.
Mooch
ERA Registry Map
If you have an ERA and want to be listed, contact me with your info and I'll put it up. The minimum info I need is chassis number and location. The rest is up to you. The most information needed would be: chassis number, body type, city, name, CC nickname, and email address.
05-06-2010, 06:45 PM
MD
Maybe this is mostly a problem with ERA's.....you know, lower build quality, etc....
www.partskeeper.com
05-06-2010, 06:47 PM
Sheesh a top loader is no gaurentee it won't happen with the linkage as well. I've been there with sloppy linkage, about to panic, WTF?, struggling to get home. Linkage was loose, no big deal. Well THATS easy to say AFTER you get home!! The Steeda uses a bolt that screws into the shift linkage AND a nut on the other side of that to lock the bolt in place. It would be pretty hard for that setup to ever come loose.
Good pic of your trans tunnel by the way, clearly it sets up much higher on the later ERA's than on the early ones? Or, your trans is sitting lower in the frame than mine is? My new TKO is same height, based on drive shaft angle and engine air cleaner clearance, as the top loader was before. But the TKO shifter sits well above the trans tunnel. I figure I will add a piece of plywood the full length of the top, round the edges off, screw it in place, cut a hole out for the shifter, add some new carpet to the whole affair. I need to re-carpet anyway...
By the way, there is a piece of rubber between the shifter lever and the TKO shifter linkage, you know, where the shifter bolts on. The Steeda install paper work said to leave that in, it helps isolate vibrations from the trans up through the shifter handle. Went for a LONG drive today, man I'm really loving this new 5 speed!
05-06-2010, 07:14 PM
ca
Cobra Make, Engine: classic roadster,408cu
On one of my first runs I was cruising down the freeway and i had passed my exit because I really didn't want to stop playing yet ...my mistake . I U turned around about 3 mi. down the road and was headed back when TKO got hard to get in gear ? about a mi. from home I pushed the clutch in and whamo the pedal went to the floor. The 2 jam nuts domed spacer and maybe some other junk were gone , as luck would have it I broke down right in front of a hardware store ! 2 6mm nuts and a washer and I was limping home .I had to push the car on the entrance of a driveway to gain access but everyone was thrilled to help push the COBRA..WD
05-06-2010, 07:22 PM
Originally Posted by Mooch
... but because I had read this thread a while ago I knew that my shifter was loosening before it completely went out. ... It's nice to anticipate problems, because of this forum, before they get full grown.
I think you should send me a present. Chocolates, nuts, a nice book. It doesn't have to be much, just something that shows how much you care about me.
05-06-2010, 07:26 PM
A. Thank you Mooch for giving me the opportunity to pile on my ole opponista.
B. Where was I last July that I missed this thread?
C. Glad you didn't need the second bar- but it didn't help in this case.
D. Pity, you never got to the haberdasher that day...
E. From Rick: Are you sure you know how to work on that car????? Talking to it doesn't count. Rick L. More correctly, talking ABOUT it doesn't count.
F. At least Rod, Rick, El and Ex administered the appropriate beating in my absence.
G. We'll all chip-in and buy you a Factory Five! Then all ERA owners will no longer have to bear the stigma of having you on board.
Chas.
05-06-2010, 07:33 PM
Well I'm glad I was able to make your night, Chas.  Mooch still needs to send me a present.
05-06-2010, 09:30 PM
Ca.
Will a big box of nuts and bolts fix the problem...........
05-06-2010, 11:41 PM
Regularly Offensive
ca
Cobra Make, Engine: spf
You know Patrick, I think you may be looking for an automatic transmisson if you keeps happening to Eraa. I can see it now; ffr...auto....single roll bar ...
Ed
Too close for missles, switching to guns.........
