1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
07-06-2009, 05:43 PM
Originally Posted by Got the Bug
Better? Maybe.... But Cooler? No.
07-06-2009, 05:50 PM
CA
True. The stock SPF dog leg shift arm also works with the Steeda kit, so some of the cool factor remains.
Doug
07-06-2009, 05:51 PM
If your car would have been powered by a stroked small block the issue would have never happened. That old POS 428FE vibrated the screw loose, the whole car is about to self destruct.
07-06-2009, 05:54 PM
You know as acerbic a comment as that is, there is some truth to it. The FE shakes the car a good bit and there is constant vibration that undoubtedly has led to my last two "don't let this happen to you" threads.
07-06-2009, 06:01 PM
Loctite is good, safety wire is alot better, Mr. Vibrator
07-06-2009, 06:02 PM
CA
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
I have a 54 mile commute to work, and while leaving work (and of course with everyone watching me pull away...or try too) my Finishline shift handle snaps at the weld where the bent handle attaches to the 2-hole portion as shown in your photo. Really bad weld...
So in So Cal traffic I drove 54 miles with a glove on my hand (hotter than hell) and shifting with a screw driver through the hole to gain some grip, yet with no leverage. I since then purchased a solid billet shifter, and swore never to use the other one again. I missed the look so much though, I rewelded it with a great weld and put it back in.
I am looking at this post though, and am thinking if I should put the short billet back in....man, that was a rough one. Good to know this stuff just does not happen to me.
07-06-2009, 06:37 PM
Originally Posted by RICK LAKE
What's irritating is that I had her up and went over her pretty well just last week. It's those pesky bolts and screws that I can't see that keep biting me in the a$$.
07-06-2009, 07:56 PM
WI
Tropical Buzz
07-06-2009, 08:16 PM
Originally Posted by Buzz
This evening I've vowed to simply ignore caustic comments and take the high road... as difficult as that may be.
07-07-2009, 09:10 AM
Drill holes through the other side of the bolts. They may come loose but will not come out.
Well I fixed it this morning. On your advice, I used a pretty serious nut on the back of the bolt. Take a look...
07-07-2009, 09:26 AM
WI
What a Buzzkill!
Ok buddy, I'm with you. As for the loose shifter bolts - been there twice. The first time it was the top bolt that worked its way out and I used some wire to tie it up and continue to the nearest hardware store. The second time, the shift handle actually broke across the bolt hole. I had shortened the handle by grinding a flat section above the old top hole and drilling a new one. There wasn't enough meat left and the darn thing broke right off in the middle of an upshift. Luckily I had visegrips in the toolbag and that became my shifter for the rest of the afternoon. Looked pretty trick actually - if you squinted and tilted your head just right, it kinda looked like a lenco or some other fancy drag setup.
Tropical Buzz
TX
I had a similar experience on my Classic Roadster which has a T-5Z
transmission. The throw in shifting got very long and sloppy while on the
way to a cruise-in. It worked ok until I made it home. the two bolts went
through the post and were screwed into the lever which was threaded. One
had worked free and the other was lose. I got longer bolts and put nuts with
lock washers on the other side and no more problems. No interference with
the added length.
Flip
07-07-2009, 10:35 AM
Ca
That location and the back and forth motion would be best served by a couple of shoulder bolts. A normal grade 8 bolt with threads baring on the surfaces within the hole of the shifter and the "Stub" from the transmission will ultimately elongate the hole, causing looseness and damage to each part.
http://images.google.com/images?hl=e...title&resnum=1
Rick
07-07-2009, 11:53 AM
TX
This could have been avoided had you installed your head gaskets and set your timing correctly.
07-07-2009, 12:08 PM
Wow, now I have been taught 3 things on this thread. Dont use a big block, check my gear shifter bolts and what acerbic means. I like the word so much I am going to use it at work.
a⋅cer⋅bic /əˈsɜrbɪk/ Show Spelled [uh-sur-bik] Show IPA
Use acerbic in a Sentence
–adjective
1.sour or astringent in taste: Lemon juice is acerbic.
2.harsh or severe, as of temper or expression: acerbic criticism.
07-07-2009, 01:12 PM
Patrick doles out an occasional acerbic comment from time to time, especially when speaking about FFR's. I'm sure it was just late at night and he was tired. We all have our moments.
07-07-2009, 01:42 PM
NY
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Gee, I thought that acerbic was a guy from one of those eastern European countries that you can't quite find on the map.
Jim
07-07-2009, 03:04 PM
WI
I always thought a cerbic was one of those bits inside a woman's private parts. And he also called me 'caustic'. That has something to do with white people of European descent, right??
Tropical Buzz
07-07-2009, 03:45 PM
Indeed. That, coupled with the fact that we also have houseguests.
07-07-2009, 04:45 PM
Ma
Cobra Make, Engine: Kirkham 592
Jeez the Kirkham has a quality shifter that comes with the car for a tremec. Too bad ERA doesn't. It's funny that FFR has a quality shifter as well
hmmmmmmmmmmmmmmmmm
