09-01-2009, 12:38 AM
I agree, the 235X60X15's look fine, fill up the wheel well nicely. On the OLDER ERA's that was the recommended size, the newer ones can accept a slightly larger tire. I was running the Goodyear "Bill Boards" and the FRONTS in particular are taller, wider than the 235's. Either tire looks fine. BUT, the big Goodyears actually did rub a little when turned to the extreme, the 235's do not. Not a bad rub, it was OK. I suspect the Bill Boards would not rub at all on the newer ERA's.
I'm currently running 235X60X15's on the front, 295X60X15's on the rear. They seem to be slightly smaller than the Bill Boards, which I will most likely go back to, soon, for increased traction. Just because it's "only" a street car doesn't mean you should sacrafice traction!
