Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Everett-Morrison Motorcars -- Speak with Julie and Brett
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 06-24-2015, 04:28 PM
Default Everett Morrison ball joints
Does anyone know of the of the replacement part for a 93 EM front upper balljoint. It is the thread in type for the tubular A arm.
Old 06-25-2015, 06:01 AM
55312's Avatar
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
The first thing you need to determine is what type of front end it is. My 92 EM uses a typical Mustang II set up. E-M use to offer Corvette suspensions as an option. Before you can figure out the ball joint you need to know Ford or Chevy. My manual is no help for part numbers. What I've done for almost every part I've needed is to take it to a good parts store and throw it on the counter. I've got a couple of Wizards here in VT that I haven't been able to stump yet. If you know the ball joint is bad, take some pictures of the control arm set up , Remove the ball joint and head to your local NAPA or PEP Boy's or whoever you use for parts. Good luck.
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
Old 09-11-2015, 08:10 AM
Moog ES2128RL
In stock - $38.65 + priority shipping $12.65
Everett Morrison
Old 09-11-2015, 08:36 AM
BADSN8K's Avatar
Cobra Make, Engine: BD 1445 Coyote TKO 600 3.91
EM didn't make suspensions! Mine was a C5 Corvette. Look at it more closely or take to a Garage and have them identify if you cannot. Good Luck!!!
Old 09-11-2015, 11:23 AM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Screw in ball joints were originally Chrysler products; Moog #719 or 772 (usually upper) and 727 (usually lower). For Cobras I would avoid the replacement market (except for MOOG or TRW) and go with Coleman Racing. Much higher quality, and a lot more travel before binding. Also helps with alignments. Check the sizes with a micrometer first--I have seen 719/772's used on both upper and lower. If you use a Mustang II spindle, it would have the K772 to use the correct taper. Readily available at any good parts house or Coleman Racing.
Ball Joint, Mono-Ball, Upper, Chrysler, K-719
Good luck!
Robert
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 09-11-2015, 02:04 PM
Tom Wells's Avatar
Chainey,
X^2 on the MOOG K772, It's the front upper (and probably the lower too) for my 1999 E-M with the tubular upper and lower A-arms.
I could even let you borrow the special socket for those if you were nearby
Tom
Old 09-11-2015, 06:11 PM
427sharpe's Avatar
Originally Posted by cobra_maker View Post
Moog ES2128RL
Everett Morrison
This is a tie rod end, not a ball joint. Moog ball joints start with 'K', and in Moog nomenclature 'ES' are tie rod ends, 'RL' means right & left are the same by application.
Old 09-14-2015, 11:39 AM
You are correct- our mistake! The real number for the upper ball joint is AFCO 20034. In some cases the screw joint in the upper arm can get wallowed out. We have seen an insert to fix that and there are some places that sell the upper tubular arm with the new ball joint. The fitting is an Acme thread which is a flat edge so don't make the mistake of thinking the threads have been stripped. Only in a few cases is that true. Ours are $29.50 ea plus shipping.
Display Modes
