December 2024
  #21 (permalink)
Old 07-13-2010, 09:03 AM
Jerry Clayton's Avatar
You got to raise your standards and leave out the term "this year" Life is lived day to day
Did you ever straighten out the routing of your spark plug wires?
  #22 (permalink)
Old 07-13-2010, 09:06 AM
That's right after I fix my handbrake, which partially works, but not on a hill.
  #23 (permalink)
Old 07-13-2010, 04:37 PM
dcdoug's Avatar
BUT, coolness is the watchword, and a remote filter answers the call nicely.
What kind of call do those blue and red anodized fittings answer?
www.partskeeper.com
  #24 (permalink)
Old 07-13-2010, 04:54 PM
The Call of the Wild.
  #25 (permalink)
Old 07-13-2010, 05:13 PM
FUNFER2's Avatar
bling,.....bling factor.
Regards,
Kevin
  #26 (permalink)
Old 07-16-2010, 05:57 PM
Cobra Make, Engine: CMC,Ford 302
Has any one used the same remote filter set up on a small block? I bought the remote filter mount and the screw on piece to replace the filter on the block to make it easier to hook up the oil cooler. I'm still eyeballing the engine bay to see what will look best and yes I like the look of the red and blue fittings (Race Bling!!)
  #27 (permalink)
Old 07-16-2010, 06:15 PM
If you have a copy of "40 Years of Cobras" there is a gorgeous photo of a 427 standing alone and it shows a good view of the pump mounted remote oil filter.
Don
  #28 (permalink)
Old 07-16-2010, 08:22 PM
LMH's Avatar
LMH LMH is offline
I haven't seen it adapted to a small block but I plan to on my 351. If you use an Edlebrock water pump, it has tapped bosses that a fabricated mounting plate could be attached to.
Alba gu brąth
  #29 (permalink)
Old 05-13-2011, 11:59 AM
Cobra Make, Engine: Hi-Tech 347 Ford 450HP
Will the finishline oil filter mount also fit the 302 water pump?
  #30 (permalink)
Old 05-13-2011, 05:25 PM
LMH's Avatar
LMH LMH is offline
No. The FE bracket for the remote oil filter is totally different than what would fit a small block.
However, see my previous posing.
Alba gu brąth
  #31 (permalink)
Old 05-13-2011, 07:27 PM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Especially when they work!
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
  #32 (permalink)
Old 05-13-2011, 09:13 PM
Default Remote filter adapter
Thanks LMH
that is what i did this afternoon
  #33 (permalink)
Old 05-13-2011, 10:45 PM
Barnsnake's Avatar
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
I mounted mine on a Windsor on the front of the driver's side cylinder head. It is mounted on a piece of aluminum plate that stands out ahead of the cylinder head. The plate is attached with 3 studs using pieces of pipe as spacers.
There are a couple of pictures on page 2 of my gallery.
Jim
A Gnat! Quick, get a sledgehammer!
