November 2024
Old 08-17-2012, 07:13 AM
Default 428CJ with dove aluminum heads excessive oil consumption
I have a 1966 428CJ that is using 1 quart of oil every 150 miles. The engine was completely rebuilt and has Dove aluminum heads, an edelbrock intake and a holley 4 barrel.
The car is dry underneath, leaks no oil, doesn't smoke and runs strong.
Any ideas??
I've read about intake gaskets getting pulled to the side and allowing ecessive oil to enter the cylinder. I'm wondering if this could be the issue?? Or could it be something else??
Thanks for the help
Old 08-17-2012, 07:24 AM
Jerry Clayton's Avatar
Several years ago---back in the 50,60,70s-----it was pretty common knowledge that a quart of oil every 100-200 miles could be the result of even a single defective/missing valve stem seal
Old 08-17-2012, 08:29 AM
Clois Harlan's Avatar
Jerry is absolutely right. My first FE engine (a 428) built by a guy named Randy in OKC) had the exact same problem. Easy and cheap fix.
Clois
"Let's roll"
"Be part of Something Good
Old 08-17-2012, 08:32 AM
undy's Avatar
My bet's on the intake gaskets or Dove porosity.
Too many toys?? never!
Old 08-17-2012, 09:27 AM
rpatton3's Avatar
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
I would check for intake manifold gasket leak because of complexity of angles involved, then valve stem seals and then proper crankshaft ventilation.
I had a 427 FE than needed oil before a gas refill. No leaks while parked, either.
It was a combination of above problems.
Best wishes,
Russell
There were no atheists in the foxholes.
Old 08-17-2012, 01:03 PM
AKA EDDY's Avatar
Cobra Make, Engine: BDR #648 351w/385hp
fdjake, check your spark plugs. Make sure you aren't running too rich.
Old 08-17-2012, 03:20 PM
To burn that much oil, it has to smoke sometime, and when it smokes will tell you where to look.
Even a catalytic converter equipped car will smoke at a quart in 1000 miles.
Old 08-17-2012, 06:43 PM
Thanks guys.. I will have the intake gaskets and valve stem seals checked.
Old 08-20-2012, 06:46 AM
Danr55's Avatar
If it's loosing oil and everything is dry underneath, then there is only one place it could be going. Out the exhaust pipe. Sounds like you're on the right track.
Dan in Arizona
CCX3209
