January 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
3Likes
03-30-2013, 03:43 PM
Well now, if "posts per year" is any benchmark of savvy....
Advertising
03-30-2013, 03:45 PM
Senior CC Premier Member
CA
Thanks Chas. I am out. Good luck Mike.
03-30-2013, 05:37 PM
CA
Really?... Really? Someone has the time to figure out how many post per year? Nice one. I guess nobody has anything else to do or say.. Again, best luck to Mike.
03-30-2013, 06:20 PM
My point was that Chas is always ragging on me for my 14,000+ posts, most of which is miscellaneous drivel. You really just have to ignore Chas. He irritates everybody, but he does so with no real malice, just crustiness.
03-30-2013, 08:02 PM
Oh in YOUR case it's real malice- AND forethought!
Chas.
03-30-2013, 08:05 PM
That's aforethought, with an "a" in front of it.
03-31-2013, 01:55 AM
ESP
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
and in the meanwhile Mike is still trying to figure out where his oil pressure is going
Nothing sounds better than a Cobra in a Tunnel !
03-31-2013, 07:03 AM
You solved it with the pump discovery, didn't you?? Still low hot pressure???
Chas.
03-31-2013, 07:22 AM
Used as a noun, either is acceptable-
Ron-WHERE is that 'LOATHE' button I begged you for????
Chas.
03-31-2013, 07:47 AM
Or maybe just a half-button.... Because, you know what they say, half a loathe is better than none.
03-31-2013, 08:17 PM
Club Cobra Member
AL
Cobra Make, Engine: Hurricane Cobra - Keith Craft 428 stoker, 600 HP/614 Trq
FE aluminum block oil pressure
I took the cobra out again and warmed to operating temperature. Oil pressure was around 20 lbs at 1100 rpms and responded quickly to rpim increases. 40 to 50 lbs between 2,000 and 2,500 rpm, up to 60 quickly at 3,000+. 60 lbs plus at anything approaching 4 to 4500 rpm. Spoke with Keith Craft and he assures me this is the tendency with the aluminum blocks he builds. If there are any problems he will take care of it. I have every confidence in Keith since I have had two other engines from him and they have performed flawlessly. Also, have two other friends with engines built by Keith and have had no issues with those engines either.
I appreciate everyone's input. Always intersting to see the wide variety of knowledge available on club cobra.
Coach Mike
03-31-2013, 08:36 PM
Club Cobra Member
AL
Took the cobra out again yesterday and warmed to operating temp. Oil pressure response quickly with any increase in rpm's. 35 to 40 lbs at 2,000 rpm, 45 to 50 quickly at 3,000 + and 60 lbs to 70 at 4500 and up.
Keith Craft explained this was typical for his aluminum block builds. If there are any issues he will take care of it. I have every confidence in Keith. I have had two other engines he built with no problems and very good performance.
Also, two friends he has built engines for with the same good reviews.
Thanks for all the information. Very impressive the wide variety of advice available on club cobra. Much appreciated.
Coach Mike
03-31-2013, 08:40 PM
Club Cobra Member
AL
FE aluminum block
Sorry for the double reply. Thought the first one got kicked off and tried to remember exactly what I posted. Again, Thanks much. Will see how it runs down the road.
Mike
03-31-2013, 09:35 PM
CA
Congrats Coach Mike. Sending you a PM.
03-31-2013, 09:49 PM
QLD
"That's a forethought" is correct grammar Patrick.
Forethought Synonyms, Forethought Antonyms | Thesaurus.com
Gary
04-01-2013, 06:50 AM
That one is a hoot!
You two are whacked!
David
04-01-2013, 07:04 AM
IL
Cobra Make, Engine: Everett-Morrison, 434 cid
Since aluminum grows more than iron, to have the same hot idle pressure, an aluminum motor will need to have tighter main bearing clearance when cold. The tighter main clearance can reduce oiling to the rods until proper temperature is reached. It's not uncommon to build aluminum blocks to have a little more clearance on the main bearings. This prevents then end user from kicking the rods out when he stands on a cold motor. As long as pressure comes up on throttle, all is well. Every aluminum race engines I've owned was built this way.
04-01-2013, 05:16 PM
Oh
A book I have on the 4.6 ltr modular said the main clearance on the aluminum block is under 0.001" when the temp is below zero. (This is based on my memory of reading the book). The author made a fairly big point that owners need to be very careful keeping the rpm down until the engine warms up.
I'm sure the bearing gap increases with temp on both the mains and the cam. No doubt in my mind that an aluminum engine would see a greater drop off in oil pressure, when warm, than an otherwise identical iron engine.
04-01-2013, 05:23 PM
KY
I set aluminum block main bearing clearances pretty tight on FE's...usually around .0018"-.0020". Taking into account that the clearances open up anywhere from .00075-.001".
Rod bearing clearances are the same as an iron block. Cam bearings get the green loctite treatment.
Lash also grows a lot more with an all-aluminum combo. Iron blocks with aluminum heads get .006" tighter lash when cold as a starting point. All aluminum engines get .010" tighter.
04-01-2013, 07:15 PM
KS
Cobra Make, Engine: jbl
that same book says the mains grow .002".
