February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 06-28-2002, 08:18 PM
Cobra Make, Engine: FFR - 460 Crate
The "385" series BB (429/460) has seven valve cover bolts. FE blocks only have six. Easiest way to identify which BB your friend has. Practically nothing is interchangable between an FE block and a 385 block.
  #22 (permalink)
Old 06-28-2002, 09:01 PM
John Montgomery's Avatar
Cobra Make, Engine: Unique 289 FIA, 351w
Cool
I'll put another vote in for Ford-Edsel.
RACECAR spelled backwards is ....................RACECAR
  #23 (permalink)
Old 06-28-2002, 10:55 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
If it is an FE there will be a seam between the head and the intake manifold that runs upward to under the valve cover.Like they said it is the onlyengine that the intake manifold form part of the valve cover sealing surface.It makes for a wide manifold a narrow head and you have to remove the rockers and pushrods to remove the intake manifold. It is a pain avoided on other engines.
Mike H
  #24 (permalink)
Old 06-29-2002, 09:36 PM
Default FE = Fairlane Engine
My Vote on FE is Fairlane Engine....George
http://www.doveperformanceparts.com/...oTheFordFE.htm
  #25 (permalink)
Old 06-29-2002, 11:44 PM
Turk's Avatar
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
Not again!
F=Fuel
E=Efficient
Someone tell Cranky they are not antique and they are not all in show cars. Some are out racing. Usually they outperform and outlast the Bearing spinning Small Blocks.
I would tell him myself, but he doesn't listen to me.
TURK
OBAMA IN in 2012
