February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 05-02-2003, 09:21 PM
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
Red face 427 alum flywheel
any one using an aluminum flywheel ?I just bought another car,,a shell valley with a fresh 427 from John Chiaccy,,{howeveruspellit}
it's 427 so,.030 over,steel $ crank,arias pistons,10.5,comp 294 cam with roller rockers,new dove high rise top end with new dual 715 holleys,balanced and blue printed,new alum flywheel,my question is the motor dosent seem to rev as fast as I expected,,years ago I had 427s with old style alum flywheels,,if u floor kicked it at idle,,u couldnt get out fast enough to not rev limit it,,this motor is brutal fast at 3500 rpm and up,,but revs like a 390,,any one have input ?thanks,,Tk
"burn em if you got em"
ar,,
Old 05-03-2003, 05:32 AM
Misfit Maybe the larger cam and 2 715 holley carbs have something to do with the problem. Is the timing good? Who set the motor up, are the carbs too rich or lean. Fuel pressure OK? Check the basics first then go to a Dyno. Is the cam retarded or advanced?? This will change the motor overall preformance. Need info to help with the problem??? Rick Lake
Old 05-03-2003, 06:49 AM
Default 427 flywheel
Thanks for the interest on this,,I spoke to th eguywho built the motor and he seems to know his stuff,,{John Chiaccy} I think you guys may have something,,I can tell the car is rich,the guy had it idleing off the rear carb which I corrected,,I have it down for paint now,,as soon as I am back up,,i will ck the timing and jetting,,
tk
Tk
"this whole Adult thing just isnt working for me "
