January 2025
26 27 28 29 30 31
Old 09-01-2003, 08:31 PM
surfer44's Avatar
Cobra Make, Engine: Hi-Tech Serial 0122 66 428, Tremec 3550. AMP 9" Ford IRS
Send a message via AIM to surfer44
Default Pilot Bearing for 428 & Tremec
I've got a 66 428 and a Tremec 3550 trans. What pilot bearing do I have to use? I've tried all local shops and come up with nothing.
Thanks,
Neil Brady
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out and loudly proclaiming:
"WOW, what a ride!!!"
Old 09-01-2003, 10:05 PM
Cobra Make, Engine: LA Exotics, Ford 428
I heard house of cobras in Anaheim was pretty good.
LA Exotics '66 SC Cobra
Old 09-01-2003, 10:42 PM
The Pilot Bearing is the regular Ford Pilot bearing....Just go to any NAPA store and ask for a 1974 390 Ford Truck Manual Transmission Pilot Bearing....the only thing you need different than the Ford stuff is a McLeod tranny adapter plate and the 26 spline GM disc...all else the same and the same for the TKO II also
George
Old 09-01-2003, 11:23 PM
Default pilot bearing in FT cranks
Hey George,
Have you run into this problem? I am using a 391 truck crank for a stroker I'm building. The pilot bushing hole in the crankshaft was larger than a standard FE. I had to turn a spacer to make the pilot bearing fit. See Photos.
--Mike
They bend 'em, we mend 'em.
Old 09-01-2003, 11:24 PM
Default the other photo
nt
Old 09-05-2003, 06:13 PM
surfer44's Avatar
George
Thanks George, it worked perfectly!
Just for anyone elses information the NAPA Part No is: 615-1024 and the dimensions are: I.D. 0.67" O.D. 1.85" Width 0.50" This is a bushing NOT a bearing.
Thanks everyone for replying, that's what makes this forum great!
Thanks,
Neil Brady
