09-17-2003, 07:45 AM
CA
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I'm sure you could get the dowels at any speed shop that sells Lakewood (Vic Hubbards in Hayward comes to mind). I have a set that I bought with my bellhousing but that I didn't use. You're welcome to them but I mistakenly bought the set that need welded on rather than the offset type.
One bit of advise as your setting up your dial indicator. I spent a good hour trying to figure out how to mount the dial indicator using all the rods and the magnet that come with it. I never could figure out a way to make it work. I finally fabricated a simple L shaped bracket out of some pretty stiff steel. I secured the L bracket under one flywheel mounting bolt and I then bolted the dial indicator (without all the rods and magnet) to the other end. Once I did that, dialing the bellhousing in was a piece of cake.
Chris
