February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 08-24-2004, 08:09 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Default FE distributor Gear ,How many teeth?
How many teeth on an FE distributor gear. I moved the distributor what I thought was one tooth .Now access to the hold down bolt is imcumbered by the mech tach drive.
Mike H
Old 08-24-2004, 10:59 PM
Rick Parker's Avatar
If you have an extra cam count the teeth on it, they will be the same.
Use a stud and a nut instead of a bolt.
Rick
Rick
Old 08-25-2004, 04:25 AM
Mike H 15 teeth are on the dist gear Rick Lake
Old 08-25-2004, 09:22 AM
That works out to 24° per tooth .Wait a minute the crank turns twice to the distributor== 48°.I went from 12° atdc to 36° bftdc==48° I'll see how muuch sweep I can get with just moving the distributor.
Mike H
