January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 08-27-2004, 12:21 PM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Thanks for the info I will find out what gear I have on the cam.
I do know that they changed the gear on the distributor I am guessing to a bronze but not sure on the cam. The cam was a custom grind.
  #22 (permalink)
Old 08-27-2004, 03:40 PM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
Priobe,
Just to clarify; the cam gear is not changeable. It either comes from the cam vendor with the std steel gear (cut into the cam billet material) or it has the optional presssed-fit cast iron gear.
If cam has steel gear - distributor needs bronze.
If cam has iron gear - distributor gear is stock.
If you use bronze dist gear be prepared to check occasionally for backlash and replace as required.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
  #23 (permalink)
Old 08-28-2004, 05:09 AM
Proibe If you run an external oil pump or dry sump, you should never have to worry about the dist gear. Make sure the end play is no greater than.004 on the cam. If you put a small groove in the lower housing of the distrubutor this will help lube where the gears meet and prevent wear out. Comp Cams sells a polymer gear. I have one but have not but it in a motor yet. Was told it is as strong as steel and will not wear. Is this motor an endurance boat motor from the spec I see? What are the tork readings, hp is great. This are a different combo than anyone else runs, like to see how it works out. Rick Lake
