January 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
12-23-2004, 04:17 PM
OK
Collateral Damage
To cold to drive the Cobra and presently impossible since I am awaiting my new engine build I thought I would post a picture of some of the internal damage to my cam, lifters, valves and #1 piston (notice the rod was twisted off from my crank), the block had a small hole in it the size and shape of Florida too.
"Let's roll"
"Be part of Something Good
Advertising
12-23-2004, 04:21 PM
OK
Let's try a little bigger picture:
"Let's roll"
12-23-2004, 04:25 PM
I think the cam needs work.
12-23-2004, 04:27 PM
La.
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
that looks like an official "dammmnnnnn"
What let go Clois? any idea why?
regards
Pull a gear .... drop the hammer .... and enjoy the Drive !!
12-23-2004, 05:10 PM
GA
Cobra Make, Engine: I Wish, Just an old truck with an FE
Ouch!!
12-23-2004, 05:41 PM
NC
Cobra Make, Engine: Its red (or Blue) with a 427 and completely fictional.
Wow, what happened to that poor FE Clois?
Mike
9-11 Never Forget
Fear starts with FE
12-23-2004, 05:47 PM
Give some JB Weld a try on that cam.
12-23-2004, 05:48 PM
Il
Cobra Make, Engine: SPF#1245 w/ 1966 427 SO
Yikes! That's too bad. I hate seeing an FE bite the dust. Do you know what happened?? I think you're supposed to put oil in there somewhere!
12-23-2004, 06:36 PM
I dont think I would reuse those parts
12-23-2004, 06:55 PM
OK
During the last session of the day at Texas Motor Speedway Jay told me I was third fastest so I changed rev my 6000 RPM limiter with a 6700 or 6900 limiter. My competitive juices told me I could be faster if I could get a few more RPMs on the front straight a way. After changing limiters and running about 20 mins into a 30 minute session coming out of turn 2 I noticed my oil pressure fell from 50 psi to 5 psi (I suspect that was when the #1 rod bearing spun) so I pulled into the hot grid and my oil pressure climbed back up to 50 again ( I reasoned the drop in oil pressure was because of the 38 degree banking). Two laps later while passing a Viper and a Vette I heard this swoosh and my engine went quiet. I got a little loose for a moment and coasted into the pits. First thought was that I had lost a freeze plug since it was missing. Not so! The old 428 CJ was really hooked up and pulling like there was no LIMIT before everything went quiet.
There are other bent and broken parts but I think from the looks of things you can tell the engine was pretty much toast.
Clois
"Let's roll"
12-23-2004, 07:38 PM
NY
Cobra Make, Engine: Shell Valley- smallblock grenade w/ the pin pulled
WOW! what carnage! I'm proud of you. You done good! I especially love what you did with your con rod! May I have that please?
"If you're not racin' it, you're wastin' it!"-Me
12-23-2004, 07:45 PM
Cobra Make, Engine: BDR 302 AFR 165
Dang that's cool. Is that one of those speed pro hyper pistons or forged? they alway run best before they grenade. Now's the time to up grade. good luck
12-23-2004, 07:48 PM
what kind of rods are those more pictures please. More info please. What motor size?
12-23-2004, 08:16 PM
AZ.
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
So what did the autopsy show went first?
12-23-2004, 09:00 PM
TX
Cobra Make, Engine: Scratch build......a little every day.
I'll give you $5 for that piston, rod combo. The stories I could tell. Is that a Comp solid lifter camshaft? What's your next build going to be?
Dave
elgecko
55 mph is unsafe at any speed. Huh?
12-23-2004, 09:16 PM
12-24-2004, 12:38 AM
VA
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Yep,
428's don't like to spin much past 6000. The rod length to stroke ratio stinks and you only have a cast crank.
Better luck with the next one.
David
12-24-2004, 12:50 AM
FL
Cobra Make, Engine: What Cobra?
Those things will still bring good money on E-Bay.
TURK
OBAMA IN in 2012
12-24-2004, 04:26 AM
OK
You ask for it so here are a few more dollars on the table. I positioned the piston to show where it impacted the cylinder wall.
Notice the the rod bearing end how smooth it seperated from the long part of the rod. Also, take a look at the bearing to the right how it apears to have melted on the crank. Below the piston on the lower left is the cam thrust plate (what's left of it). Unshown are the bent push rods (only three noticable to the eye) and the other rod bolt.
This could be arranged into some kind of modern art exibit.
"Let's roll"
12-24-2004, 04:30 AM
OK
Here is the crank already turned .040 and may have one good turn left but I won't use it in any engine I intend to race,
"Let's roll"
