February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
  #21 (permalink)
Old 08-27-2006, 08:00 AM
NKOTB's Avatar
Cobra Make, Engine: 94' ccx33835, Shelby dark blue street style, 428PI, toploader.
Send a message via AIM to NKOTB Send a message via Yahoo to NKOTB
Dan,
You are correct, the smooth hood was standard, but I'm not clear on if a scoop would have been more common as a dealer installed option, or as a from-the-factory ordered option... either way, you are correct that it was an option & I have no idea how many were factory installed (rivited) as you mention, vs glassed on... I did find one street with a riveted hood (csx 3260), but the two smooth ones make me wonder how they got that way... (making me mental) I guess if I'm going to have to keep the scoop to get the engine "right", then I want the scoop to be "right" too.
What I do have is a PI intake on 427 low-rise heads... I've not heard that is is a mis-match before. Guess I'll know for sure when I get it to Southern Automotive in the coming weeks.
Thanks for the info,
DD
DD
  #22 (permalink)
Old 08-27-2006, 09:21 AM
Cobra Make, Engine: CSX4000, 427
Originally Posted by NKOTB
I bought my car just a about a month ago, and am in the process of refreshing it in terms of general PM, tuning, and authenticity. I'm heading in the pure street style direction(no side pipes, no scoop, no stripes, no bar), and am currently mulling over what to do with my engine in terms of it's height in the frame - it sticks up about 1-2 inches above the hood plane. What I think I have is a 428CJ (C6ME, 352 stamp) block with iron heads, a C3AE-H 427 low rise intake and a holley 750 1x4 carb setup. Part of me would like to get the height down so I can use a solid hood, a la' steet style, and I'm thinking a blue-thunder mid-rise intake would get me there... but I have come up with the following questions for the group:
Questions:
- Is there anything particulary good or wierd about the build I have?
- In terms of street style authenticity, other than 2x4's, am I headed in the right direction?
You don't seem to have anything that's out of the ordinary, higher than normal. You may want to find somebody else with a FE contempoary and compare engine mounts.
Because a cobra hood is rounded, it is higher in the center than at the edges. I found a good way to measure hood clearence was to get a radio antenna, and tape it to something inside the engine compartment where you want to measure clearence, close the hood which compresses the antenna to the maximum clearence. You may be surprised how much clearence you have.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
  #23 (permalink)
Old 08-27-2006, 10:40 AM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
...What I do have is a PI intake on 427 low-rise heads... I've not heard that is is a mis-match before...DD
David, from my previous post: "A Medium riser intake will fit on low riser heads, with a possible port mismatch."
The PI intake is a low riser intake, no mismatch there. The carbs sit lower on low risers than medium risers, so you've got all the clearance you're going to get from the motor, other than using a different air cleaner. The reason I said a medium riser intake may give you a mismatch between the intake and heads is because of what SOBRAC mentioned earlier about low riser intakes having the same port sizes as medium risers. The yellow "Ford Performance" book shows this to be the case, but there are several incorrect size statements in that book, so at this time I say they might cause a size mismatch until I get info from another source. Not that you want to install a medium riser intake on your car because of the clearance issues you already have, but FYI, you cannot port match a medium riser intake to "tall" low riser heads, as the medium riser intake doesn't have enough meat below the port to open the port up enough. The low riser intakes, PI, Cobra Jet, etc. can be port matched to "tall" low riser heads.
In short, the parts you have all match.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
  #24 (permalink)
Old 08-27-2006, 12:34 PM
NKOTB's Avatar
thanks Dan. I'm better now. ;-}
DD
