08-28-2006, 12:42 AM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by Excaliber
...When my motor was 12.5 to 1 the sound could be likened to a "Funny Car", deafening (with the sidepipes removed and open headers). Truly unbelievable earth shaking move away from the car 'cause DAM, it was loud! I was also running a VERY radical cam, which could have also enhanced the sound. Changing to 9.8 to 1 and a milder cam it now sounds quite tame in comparison, even with open pipes it is considerably quieter. I run iron high riser heads (1964 from a T-Bolt car).
I suspect the original FE 427's sound was different than we typically hear today. The original motors were generally well over 10 to 1, with 11 or 12 being common.
I agree, I think it's a combination of compression and, especially, a good roller cam. My cam is fairly big, but streetable enough for me. I wouldn't want one much larger...I also just changed my carb linkage to progressive instead of both opening at the same time...that improved driveability a bunch. Getting back to SCOBRAC's comment though, I must admit mine isn't as loud as it was with the iron heads...it sounds just as "nasty", but not as loud...and believe me, my glasspacks have to be blown out by now.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
