February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 11-05-2006, 02:49 PM
Default Tada.....
Dyno'd my 428FE Friday afternoon.
http://www.youtube.com/watch?v=qG5wAu3WUcQ
http://www.youtube.com/watch?v=qb9FSKNQRJY
It made 533hp @ 6500 and 472lb-ft @ 5400. Made 12 pulls to over 6500 without any problems.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 11-05-2006, 04:33 PM
Cobra Make, Engine: ERA 427 #708, 427 SO
Very nice.
Sounds awesome!!!!!
CB
Old 11-05-2006, 04:49 PM
That first video, two rusty tail pipes sticking out the back of a building? Only 'real' motorheads could appreciate such a vid, (it was cool, great sound track).
Old 11-05-2006, 05:09 PM
LMH's Avatar
LMH LMH is offline
Excellent!
Really good numbers and it sounds great! Congrats!
Old 11-05-2006, 05:18 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Great job! That building has a mean idle!
Old 11-05-2006, 05:48 PM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Hey Brent,
Can you tell me exactly what kind of break-in procedure you went through, where you did it and what you did before you started cranking it up to the higher RPM's?
The engine sounds really impressive, way to go.
Old 11-05-2006, 06:11 PM
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
WOW! Pretty exciting 16 seconds, huh? Sounds great!
Thanks,
Lowell
Old 11-05-2006, 06:17 PM
Mark,
It was ran for about 30 minutes at about 2000 rpm. It's a roller cam, so no breakin was needed....just cranked it, started it, set the timing, and let her go.
After the first 30 minutes, we shut it down and ran the valves, did maintenance, etc.
Then we did several more 20-30 minute runs (basically heat cycles) with a little load on the engine.
Next came a pull to 6000...and again we checked the valve lash, etc.
Then we made about 10-11 more pulls at around 6500-6600 while playing with timing, jets, vac springs, dizzy bushings, etc.
It was done by Performance Engineering in Cincinnati, OH.
Great bunch of guys.....really hard workers and very knowledgeable.
Old 11-06-2006, 12:06 AM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
VERY sweet, blykins. Congratulations!
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
