November 2024
Old 01-12-2007, 09:09 AM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Question Timing 427 sideoiler
Hello All,
Hopefully this is a straight forward question to ask.
What should I set the timing for a 427 side oiler with Webers?
MSD iginition
Thanks
Old 01-12-2007, 09:34 AM
marcocsx3121's Avatar
Cobra Make, Engine: Owned CSX 3121 1969-1975. Went to the dark side and bought a 'Vette. May yet repent and be saved.
About the same as a center oiler with Webers.
Old 01-12-2007, 11:58 AM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
My KC built aluminum side oiler block and heads, with a carb,... the max advance is at 40 degrees.
Old 01-12-2007, 01:49 PM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default I would recommend not more than 36 degree
Somewhere around 12-15 initial and 36 total is safe and should be all in by 3000 rpm's.
Morgan LeBlanc
Fresno CA
Old 01-12-2007, 01:52 PM
priobe's Avatar
Thanks RedCSX1
