December 2024
Old 01-24-2007, 02:39 PM
joey_hv's Avatar
Cobra Make, Engine: Joey Manufacturing Inc.
Send a message via Yahoo to joey_hv
Default 427 recently rebuilt for $450???
guys,
I work with some good ol' boys from North Louisiana.
One of them has a "cuzin" that has a "recently re-built" Ford 427 side oiler for sale for $450 bucks. He says he's had it for years and "aint no'one buyin' it"
am I missing something here? did I just run across one of those probervial dream car in the barn deals?
are all Ford 427's the same or could this be the one casting that is only worth $450 bucks??
I'm thinking of buying it just to see what it turns out to be.
the "cuzin" works at CarQuest auto parts so he gets rebuild kits next to nothing but I would think he would know what he had on his hands..
im confused.
"Me fodder was King Neptune, me mudder was a mermaid. I was born on the crest of a wave and rocked in the cradle of the deep. Me hair is like hemp, me arms are like spars. When I spits, I spits tar. I'm hard, I am, I is, I are. "
Old 01-24-2007, 02:46 PM
427SnakeSC's Avatar
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
Cool
Sounds like an urban legend, to me!
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
Old 01-24-2007, 03:15 PM
imagine2frolic's Avatar
Cobra Make, Engine: n/a
Send a message via Yahoo to imagine2frolic
Go to a bookstore, and buy a book on casting numbers. That will tell you what it is.........
Old 01-24-2007, 03:24 PM
joey_hv's Avatar
It does seem hard to believe. We're calling the cousin tonight to get numbers off the case. maybe pictures.
stay tuned...
Old 01-25-2007, 09:45 AM
Cobra Make, Engine: TBD, other is 67 Mustang GTA 390 Convertible w/air,
Send a message via Skype™ to fostereast
Default Buy it if it has screw in freeze plugs!
That's a sure sign it's a sideoiler or a later center oiler.
Old 01-25-2007, 10:00 AM
flwolfman's Avatar
Cobra Make, Engine: None at moment
It could be a 427. I bought one last year on a deal like that. Jim
Old 01-25-2007, 10:04 AM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Dont be too excited when you call him. Offer him $400 to take it off his hands.
What did you say his phone number was ?
Dave
55 mph is unsafe at any speed. Huh?
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
I'd think a real sideoiler would have easily sold for $450. Even just the block. Sure he didn't drop a "0" off the end of that price? For sure tho worth the time looking into it. FWIW lots of FE blocks have the rear bulkhead mold of the sideoiler cast into them. This carries the "66-427" cast into the block as well as the blank rear oil galley/releif valve boss. Guys confuse this with the real deal all the time. Easy to understand if someone does not know lots about the oddities of the FE. As it is cast right into the block. Well let us know how you do and I hope it is a real sideoiler!!!!
G.
Old 01-25-2007, 10:15 AM
DAVID GAGNARD's Avatar
I'm a good ole boy from central Louisiana, want me to check it out for ya?????????? course when I find it is a real 427, I'll have to take it home with me and tell you is was just an old 390 block!!!!!!!!
What's his # again?????
David
DAVID GAGNARD
Old 01-25-2007, 12:44 PM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
The old saying, "If it's too good to be true, it probably is." always applies. But just in case check out the numbers on the block, heads and manifold. It would be good if you could check out the bottom end, too. If it is a "real" one, buy it, then I'll give you $1,000 for it.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 01-25-2007, 01:40 PM
Rick Parker's Avatar
Are you are looking for a reason to justifiy purchasing a real 427 for $450.00?? Lets say it's NOT a real 427, maybe a garden variety 352,390,406 etc (FE). Is it worth $450? If it is recently rebuilt, of course it is. If it turns out to be a 427 you hit paydirt. I'd beat a fast track over to the Cuzz's barn and find out if there is an engine or a rebuild kit that is being "Back Doored". Better yet have David go look for you, he'd know what he was looking at!
Rick
Old 01-25-2007, 02:04 PM
joey_hv's Avatar
Default casting numbers gentlemen
casting numbers as promised
Heads C7je-6090-a Motors ,rear Of Block 66-427, Side Of Block 12-dif
Old 01-25-2007, 02:31 PM
does the (a) indicate marine use? what location is the 12 for?
Old 01-25-2007, 06:07 PM
You'd be surprised at the "barn finds" still out there........a couple of years ago a buddy was going thru a storage shed in an old country junk yard and came home with a short-block 427 for 200 bucks, probably could have got it for less, but he made the first offer and the old guy took it..........that very same engine went thru a rebuild and was stroked and now resides in a 9 second late model drag race mustang................
I've seen all kinds of stuff over the years......at a nearby junkyard there are 2 hemis sitting side by side, one is a 392 cu in (I think that's the right cu in for the early hemis) and the other is ???? cu in, but the original valve covers say "DESOTO" on them, both engines are complete from water pump to flywheel and carb to oil pan....thankfully they are stored in a shed out of the weather.........
David
DAVID GAGNARD
Old 01-26-2007, 04:43 AM
FFR428's Avatar
Those are 427 marine heads. It could be the 300hp 427 marine. The 12 DIF you see really means nothing important. DIF is the foundry it was cast at..Dearborn Iron Foundry. The 66-427 may or may not mean it's a 427 as I said above. If it is a marine 427 it will have brass screw in freeze plugs. Watch if the block has been run in salt water most of it's life. These ran in both open and close loop systems so it could be either if it's a marine engine. Another thing to watch is the rotation of the crank as marine engines also used reverse rotation in twin screw yachts. The oil slinger grooves on the rear of the crank are machined in the opposite direction. This can cause a rear main seal leak when used in standard rotation applications. I'd ask for good pics of the engine. You'd want to see the crossbolt mains if it was a 427 or ask him anyway??
G.
Old 01-26-2007, 05:18 AM
joey_hv's Avatar
great info, thank you for taking the time. it probably came out of some old shrimp boat.
Old 01-26-2007, 09:26 AM
FFR428's Avatar
I should also mention both topoilers and sideoilers were used in marine production. The blocks for the most part were cast as sideoilers but drilled for topoiling. While the majority was topoilers there were some sideoilers used in boats too. The marine topoilers won't have the rear sideoiler galley plugs, or the side and front plugs machined and installed. Some even have the sideoiler galley "hump" as it's called shaved to clear for motor mounts. The sideoiler galley is cast on the left side of the block right above the crossbolts. Easy to spot. Maybe someone can post a pic to show you exactly what that area looks like. And also the rear of the block too. If the block had a crusty saltwater lifestyle it's porous as a sponge possibly. I've seen a few that would make you cry. But that's worst case and you always hope for the best otherwise. It could be a very good deal for you. The C7JE marine heads are actually pretty good.
G.
Old 01-26-2007, 10:26 AM
Oh those blocks ARE out there and unless your running in the right circle of friends HARD to sell. I mean, WHO would want an old rusty Ford big block from 'back in the day'? Not likely your NIEGHBOR, or even your friends. Sure it has some value, but you have to MARKET it. Like the owner said, "Aint nobody gonna buy it", and he's probably right, at least concerning HIS 'circle of friends', to them, it's just another rusty old Ford motor, no big deal.
