![Old](/forums/images/statusicon/post_old.gif)
03-22-2007, 10:37 PM
![Mike Bartlett's Avatar](http://www.clubcobra.com/forums/image.php?u=18062&dateline=1295638150) |
CA
Cobra Make, Engine: CSX4771-CF. 1966 427 S/O
Remote oil filter flow (direction)
Could use some clarification on the following.
1) With a remote oil filter should the oil flow from the block through the cooler then the filter and back to the block?
2)Does the oil flow into the center of the filter then back out through the outer edge of the filter or vice versa?
3)The two oil holes at the side of the block. Which one is supply and which one is return? Lower hole, meaning closest to the pan, upper hole meaning closest to the head.
Thank You,
Mike
Rubber peelin' gears a jammin'!
