February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #61 (permalink)
Old 08-28-2007, 08:39 PM
Cobra Make, Engine: LSC 462
going to start to put it back together tomorrow. wish me luck.
  #62 (permalink)
Old 08-29-2007, 07:34 AM
David Kirkham's Avatar
Original Shelby Owner
We sell 1:1 ratio pulleys. We are making them right now on the CNC lathe even. Keith Craft just placed a big order with us for them.
David
  #63 (permalink)
Old 08-29-2007, 07:43 AM
Jerry Clayton's Avatar
David
Do you make other pulleys also---We need a custom lower serpitine for paxton blown Elindor replica with 427 Dart block and a front accessory drive
Jerry
  #64 (permalink)
Old 08-29-2007, 08:02 AM
We do all sorts of strange things. I need a drawing, or a sample part, to give you a price.
David
  #65 (permalink)
Old 08-29-2007, 11:00 AM
Cobra Make, Engine: shellvalley 428 ford
Dragon462,
March makes a hi flow pulley for an FE in single or double groove.
1-groove is # 1552 , 6 inch water pump pulley
2-groove is # 1562 , 6 inch water pump pulley
Note, the crank pulleys are the same diameter for both. Single or double for the high flow and the performance use the same pulley respectively.
I hope this helps and good luck,
Byron
  #66 (permalink)
Old 08-29-2007, 11:12 AM
Cobra Make, Engine: KMP 498
David, What size pulleys are you making for the FE? From this thread you are underdriving the Water Pump, How much? Thanks
  #67 (permalink)
Old 08-29-2007, 04:29 PM
i have the 1552 6'' and the crank is 1911 5 1/2'' does any one know the size of the stock ones
  #68 (permalink)
Old 08-29-2007, 06:43 PM
big-boss,
Both of our pulleys are 6 1/2 inches OD.
David
  #69 (permalink)
Old 08-29-2007, 07:34 PM
can you next day them to me???? do you make motor mounts ? shannon 316-871-5267
  #70 (permalink)
Old 08-30-2007, 07:58 AM
Dragon,
Everyone is at our open track event today. I can next day them to you tomorrow. Sorry, this is the only day that could have happened!
David
  #71 (permalink)
Old 08-30-2007, 08:03 AM
Stentor's Avatar
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
Originally Posted by David Kirkham
Dragon,
David
David, I sent you a PM on a separate item.
Thanks.
  #72 (permalink)
Old 08-30-2007, 09:17 AM
Dragon462,
I posted the question on the FE forum as well. The standard water pump pulleys for an FE range from 5.82 inches to 7.375 inches with different combinations of crank pulleys so I do not believe that you have a pulley issue.
Good luck,
Byron
  #73 (permalink)
Old 08-31-2007, 05:33 PM
thank you do you know the size of the crank pulley???
  #74 (permalink)
Old 09-01-2007, 05:34 PM
The March is 5 1/2 and I have a single sheeve factory 68/69 that is 5 3/4.
How is the car going?
  #75 (permalink)
Old 09-02-2007, 06:27 PM
putting it together it will be running tomorrow found two thing that i fixed . it should run around 190.. got a new pulley from Kirkham Motorsports .. crossing my fingers.. and thanks to keith craft for the help...
  #76 (permalink)
Old 09-03-2007, 08:20 PM
dragon462,
What are the two things you changed and what pulley did you buy from David?
Thanks,
Byron W
  #77 (permalink)
Old 09-09-2007, 07:18 AM
Bill Bess's Avatar
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Dragon 462, My 2-cents
I too had a cooling problem with my SA 428 FE motor.
Installed a full fan shroud, removed the themostat plate restrictor, installed a 190 degree themostat..still ran hot in traffic. I checked the temp. with a infered gun and found the temp. to be within range after it got hot according to the gauge. I installed an electric gauge and compared it to the Autometer mechanical I was running.
The mechanical gauge kept on creeping up to the top and around to the bottom of the gauge as usual in slow heavy traffic.
The electric gauge went to 195...the themostat opened,,,the engine cooled a bit and then got no higher than 205 degrees on a 110 degree day.
Guess what I'm now just running the electric gauge.
Best of luck, Bill
  #78 (permalink)
Old 09-18-2007, 12:15 PM
Dragon462, whats the latest????
Byron W.
  #79 (permalink)
Old 10-10-2007, 10:21 AM
Dragon462,
Did you ever get your heating problem fixed????? You stated that you changed 2 things and purchased a pulley from David Kirkham, what were they and what pulley did you buy?
Thanks a lot,
ByronW
