February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 03-12-2008, 11:16 AM
RodKnock's Avatar
Default Powermaster Starter for FE
There was an earlier thread started by "HiTech Cobra" where Barry R was going to list the correct Powermaster starter part # for the Shelby/Pond FE using a Quicktime bellhousing. Does anyone have that part number? Thank you.
Old 03-12-2008, 11:39 AM
Rodknock ... I recently tried a Powermaster 9506 on my Quicktime bell housing/Ponds block and had a problem as the mounting holes in the three bolt starter flange wouldn`t line up with the mounting holes on the bell housing . Two would , the third wouldn`t . Went to NAPA and pulled an FE starter out of stock and it fit perfectly . I also called Quicktime and they had the same result with a stock FE starter . Looks like to me , one of the "ears" is off several degrees .... not the bell housing .I don`t know if this is one case only , or a series of incorrect flanges .... just an FYI for you . I think the number you want is 9406 , but Barry can verify that for you . My 9506 had what they called the infiniclock feature , which allows you to rotate the starter to fit , unfortunately , the flange had one ear off .
Old 03-12-2008, 01:17 PM
Cobra Make, Engine: KMP 498
Default Powermaster 9506
I used the powermaster 9506 w/ QT bellhousing. It fit OK. I had to add a shim to get the gear out of the flywheel. It is working fine so far.
Old 03-12-2008, 01:31 PM
The 9506 would fit ok .... just that you couldn`t bolt it up as one of the flange holes was off 3/32" , due to what I feel is a manufacturing/QC defect .I`m sending the starter back . I couldn`t get it torqued up to check engagement/alignment . Not really complaining as anyone can have a problem during manufacturing .
Old 03-14-2008, 06:47 AM
Clois Harlan's Avatar
I only use two holes on my FE hi torque starter and it has worked perfect for years. Contact this guy from ebay he sells an excellent starter for a very good price. The starter is made by a company in California that builds and sells starters for fork lifts.
http://cgi.ebay.com/ebaymotors/FORD-...em140214870483
I have had my starter for over 6 years with no problems.
Clois
"Let's roll"
"Be part of Something Good
Old 03-14-2008, 10:04 AM
Cobra Make, Engine: Look-a-like cobra POS
If you want an option, the Tilton starter is excellent for FE's.
B. Ewing
Old 03-14-2008, 10:11 AM
RodKnock's Avatar
I'm open to all suggestions/options and I appreciate them very much. I want a starter that's reliable and fits. I have a Shelby block with a QT bellhousing.
Do you have a part # for the Tilton?
Thanks guys.
Old 03-14-2008, 10:25 AM
Here is all things Tilton:
http://www.tiltonracing.com/home.shtml
B. Ewing
