February 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
03-19-2008, 12:04 PM
FL
Cobra Make, Engine: Hi-Tech
Blue Thunder Pent-Roof valve covers
After reading about the oil leak problems with the stamped steel chrome pent-roof valve covers, I decided to give the Blue Thunder Pent-Roof cast alum ones a whirl.
Anyone have these? I ordered mine from http://www.dscmotorsport.com.
Advertising
03-19-2008, 12:44 PM
KY
I have owned a set. They wouldn't clear my Erson rocker arm setup.
03-19-2008, 12:47 PM
FL
That's bad. I better call before they ship!
03-19-2008, 12:50 PM
FL
Do the regular chrome pent-roof valve covers clear the Erson rocker set up?
03-19-2008, 12:52 PM
KY
Not sure. They clear T&D, so probably.
The Ford Racing valve covers clear easily, if that helps.
You could always return them. I didn't mess with thick valve cover gaskets or anything...but they wouldn't set down on the head for me.
CA
Cobra Make, Engine: Cutting Edge, Boss 429
Oh I think you will have plenty of time before they ship
03-19-2008, 12:53 PM
KY
BTW, which ones did you buy? They have a regular set and a comp set.
03-19-2008, 12:55 PM
KY
Boss.....LOL
That was funny to us that know what you're talking about....
BTW Hi Tech....check out my webpage, click on the 428FE page and you can see the Ford Racing covers.
03-19-2008, 12:56 PM
CA
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
I bought the polished Shelby FE covers from them and everything clears perfectly. And not one drop of leakage! The chrome stamped steel FE covers I had before leaked like sieves. Rubber gaskets. On the cast covers I used Fel Pro rubber impregnated cork gaskets from Summit, sealed completely to the new covers with gray RTV, let sit overnight, and bolted them up.
Since it appears you also have a KC 482, you must have the same heads and pretty much the same valve train as I do. Call Keith first. I seemed to luck out.
03-19-2008, 12:57 PM
CA
I couldn't help myself. Low hanging fruit
03-19-2008, 01:30 PM
FL
03-19-2008, 01:41 PM
Originally Posted by hi-tech cobra
Let us know when they arrive.
03-19-2008, 01:44 PM
CA
I don't know. That little indentation for bolt clearance on the top side with the three bolt holes looks problematic. The finned cast ones didn't have that much indentation.
I like the cleaner look of the ones you're ordering better, but knew the ones I ordered would fit since I had seen them on the engine earlier. Keep us posted when you get them.
03-19-2008, 02:32 PM
FL
You guys think DSC won't ship? Any words of warning I need to know about? PM me. Thanks!
03-19-2008, 03:04 PM
KY
Those are the ones I had...they are not the comp covers. I think you may have trouble with them.
No, you'll get your stuff eventually...Dennis is just a little slow sometimes on shipping things out.
03-19-2008, 04:12 PM
CA
They'll ship. Agree with blykins. Took a little longer than others. As I recall he used FedEx which in my opinion is slower than the UPS service I get in So Cal. And Fed Ex wants a signature to boot.
03-19-2008, 05:46 PM
NV
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Been using the Comp covers for a few years now with no problems. http://www.clubcobra.com/photopost/s...9&ppuser=10990
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
03-19-2008, 06:00 PM
The cast aluminum 427 valve covers I got had to be ground down an 1/8 in the end sides to accomodate the dove set up ,figured it was typical .What was the erson clearence issues , at the ends also ?
03-19-2008, 07:29 PM
KY
John, it's been a couple years, but I think you're right.
03-19-2008, 07:41 PM
FL
So they will fit, I'll just need to clearance a bit?
Or do I need to specify the Comp version? What's the difference between the two?
