February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 07-30-2008, 04:07 PM
Cobra Make, Engine: unique 427
Default In need a dipstick
Hello, I installed an Armondo oil pan recently and the dipstick on my old pand came out the front and up at 90 deg on the left side. the Armondo pan has two nipples coming out the right side, I called him and the big one went up to a breather tank of some sort which I do not have and the smaller one is for the dipstick. He said that a normal 427 cobra dipstick will do but I can't seem to find one. Help please.
P.S. the Rmando pan does have a plug where the dipstick was on my previous pan but he said the oil temp sender goes there and I tried and could not get my old stick to work.,
Tony
Old 07-30-2008, 04:27 PM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Ebay is a good place to look, the classifieds on this site.
There is a guy in Ca. DSC motorsports that deals in new and used FE stuff as well.
Good Luck.
Old 07-31-2008, 08:54 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
Since the Armando (or Aviaid) pans were not a factory item on any but competition Cobras, it's unlikely you will find an "original" dipstick will work. The factory dipsticks on most FEs came out of the block on the left front, near the oil filter housing. You can use a stock dipstick in this location, but be sure to check clearance with the windage tray you likely have with the Armando pan. Finding one should be easy. Check Mustang, Cobra or Galaxie parts vendors on the Net.
If you want to use the nipple on your new pan, just go to your local auto parts store of choice and buy a generic chrome MR Gasket dipstick for a chevy big block. You'll also need a couple of small hose clamps and a 2" long or so piece of rubber hose. Carefully bend the lower portion of the dipstick so it lines up with the smaller nipple on the pan, running the dipstick tube up and behind the alternator. Use the top water pump bolt to attach the tube to the engine with the tab welded onto the dipstick tube. You may have to shorten the bottom of the dipstick tube an inch or two with a cutoff wheel or hack saw. Use the rubber hose and clamps to attach the bottom end of the dipstick tube to the nipple on the pan.
To mark the add/full lines on the dipstick, fill your engine with one less quart than full and mark a line on the dipstick. This is the add 1 qt line. Add the last quart and mark this line, too. This is the full line.
Should cost less than $20 for everything.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 07-31-2008, 01:19 PM
John Annie's Avatar
Cobra Make, Engine: ERA #661 with a 428CJ, Richmond 5 speed
Moroso makes a universal dipstick (Jegs 710-25970 - $17.99) that might work. It has a fitting for a 1/4" NPT coupling. I used one on my pan, but it is a Milodon road race pan.
John Annie
