February 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
03-09-2009, 07:36 PM
Cobra Make, Engine: FFR 390 toploader IRS
I use Octane Supreme130 http://www.kemcooil.com/specials.php
1 case last's the summer. I also use it for my Ford tractor and my 72 p/u
FFR MarkIII,FE,toploader,IRS,3.27,Vintage pin's SOLD!
68 F100 Custom Cab 418 cube FE/auto
99 SuperDuty Tuner/chipped/4" Banks TOTALED!!
02 Super Duty 7.3L
Advertising
03-09-2009, 07:59 PM
CA
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
Originally Posted by Karl Bebout
I've used av gas from the local airport and they call it 105 leaded. I add one ounce of Marvel Mystery Oil per gallon, for a little cylinder lubrication, and have never had any problems in either my 10 1/2 Rat or my 12 1/2 destroked 400 SBC. Up until the last year or two, I used to be able to drive the Cobra up to the pump but now I have to just fill a can. Guess the tax man was afraid he wasn't getting his pound of flesh.
I used to add a little Marvel to my blower motor as well.
03-09-2009, 09:25 PM
TX
I have been using the 100/110 LL Avgas I get at the small airport
where I get my skydiving fix. I just fill a 5 gal can and use my credit
card and do a rough blend of 1 : 10 with the 92 octane pump gas. It doesn't
sound like much but sure makes a difference in how the Cobra runs,
especially in 5th which is the Tremac .64. If the road is flat and level
it will cruise at 55 smoothly where without the juice I had to be going at
least 65 for it to run ok. I can go up H-3 in 5th no problem at 65 with it,
and it is just over 2,000 rpms at 80 in 5th. I'm sure the c/r is less than
10:1 but not by much. The 100LL is between $5 & 6/gal here but I also
get about 3 mpg better so I figure I'm getting the better performance for
no extra cost. Oh, and I love the smell of that AVgas!
Flip
03-14-2009, 10:33 AM
CT
Cobra Make, Engine: HM-2027 / 427 SO
We have both leaded and unleaded VP 110 octane at our local Sunoco. During spring and summer the 110 unleaded is in the pump. Leaded is in the garage in the drum. Both are $9.98 a gal. Right over the hill from me here. Sweet.
03-14-2009, 11:39 AM
CA
That's pretty expensive. I am paying $7.98 a gallon right now for F&L 111 octane from the pump in So.Cal.
03-14-2009, 11:53 AM
CT
Yep it is. But it's the only game in town.  I remember years ago when it was $3.98 a gal and thinking it was expensive then.
03-15-2009, 09:31 AM
AZ
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Here in the "Wild Wild West, "...Lake Havasu City,AZ , there are numerous boat builders that require 100 + fuel for those big Chevy motors. Then all the out of towners that come here with their boats and cars also need the stuff too.
Most all the stations including the major brands carry 100+ racing fuel, right now it's $4.50 per gallon. I use the regular 94 in my FE for about $2.09 to $2.25 at the local Standard Station......works great.
Bill
03-15-2009, 01:58 PM
$62 for a 5 gal can of Sunoco here...
Look for another source...
02 Super Duty 7.3L
03-15-2009, 03:36 PM
CT
 $62 for 5 gal is $12.40 a gal. Unless you typed it backwards and get 5 gal for $26? If that's the case I'll be coming up your way.
BTW did you ever get the 2nd package you were waiting for?
03-15-2009, 05:28 PM
sorry to say no typo there.
But yes, I did get it after FedEx shipped it back to him. I had him bring it to the post office and ship Priority. Had it 2 day's later. Didn't say anything to FedEx yet. I think there still looking for it.
02 Super Duty 7.3L
03-27-2009, 06:57 PM
OK Who Makes the BEST AV gas???????
03-27-2009, 07:02 PM
Who makes the best av gas??????????
03-28-2009, 07:03 AM
KS
Cobra Make, Engine: jbl
vp q16 is supposed to be worth quite a few hp, 20-30, according to the guys on speedtalk.
04-07-2009, 07:00 PM
MI
Cobra Make, Engine: SPF Coupe #136, 427SR FI
Hi,
I tried AV fuel once. VERY HARD TO START THE CAR.
Most likley need to mix like stated in other posts.
Jeff
04-07-2009, 07:20 PM
Originally Posted by jeffgrice
Hi,
Jeff
Never had that problem or heard of it before..... My race car will sometimes "sit" for a couple of months without being fired up and one good pump on the accelerator and hit the starter button and it fires up instantly, same as when I ran 110 or 114 octane.........
David
DAVID GAGNARD
04-08-2009, 07:41 AM
PA
Cobra Make, Engine: Look-a-like cobra POS
Best is to get a drum of Sunoco Standard and be done with it.
It will stabilize your fuel in the winter and your car will run perfect all year long. Five gallons added to 15 of premium is all you need.
B. Ewing
04-09-2009, 11:54 AM
OK
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
If you use toluene, 1:9 or 1:10 with 92, 93, 94 unleaded is about optimum. If you mix toluene too rich, you'll tend to foul your plugs, exhaust is very sooty, and it acts like it is cold natured and never seems like it gets warmed up. (Experience: hot SBC in a Vega, back in the '70's.) I also remember a '60's street racing trick of adding 1 gal of laquer thinner and a handful of moth balls to the gas tank. Don't add to much, or you'll lean out and burn a hole in a piston.
Depending on the octane rating of av gas, it can be 20-30% toluene, with the remainder being alkylate, with xx grams of lead. Alkylate (and toluene) is "heavier" than other gasoline blend stocks (Platformate, FCCU cracked gasoline, etc), so it may require a little more advance on timing to fire it off and take full advantage of it.
After 32 yrs making/blending gasoline in a Sunoco refinery, I'd suggest buying racing fuel by the drum (pick your brand) and mixing it with the highest octane available at the pump. Experiment with ratios until you get what is best for your engine combo. 80/20, 85/15, or 90/10 might be all you need. Why run straight race gas or 50/50 if you don't need it?
Just my opinion, everybody's got one................
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
04-09-2009, 02:47 PM
CA
Good post. I mix F&L 111 octane with 91 octane pump gas 85/15. It runs very well.
04-09-2009, 06:23 PM
It was not that many years ago, (10 to 12 maybe) when I drag raced my 65 fastback a few times a year at Ford only events. I had no trailer so I drove it to the track, raced it and drove it home...
I'd stop at Auto Zone, buy a gallon of virgin laquer thinner and borrow their trans. funnel, pour it in the tank and then go across the street and finish filling it up with 93 octane and head out to the track..... The tank held a total of 16 gallons, did this many times over the years till the price of laquer thinner got crazy........
still running that very same motor and it's never been apart since I built it in the early 90's..........
The guys behind the counter at Auto Zone still think I'm crazy to this day!!!!!!!!!!!!!!!!!!!
David
DAVID GAGNARD
04-23-2009, 10:45 PM
What kind of compression ratio are you running with a 70/30 or 80/20 mix with 110 VP?
