Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Like Tree4Likes
Old 08-10-2013, 02:05 AM
750hp's Avatar
Default Cross Ram EFI for FE?
Does anyone sell an EFI or Weber cross ram intake for an FE?
I've seen this tunnel port intake from the old CanAm days, but I'm interested to see what is more readily available.
Craig
Old 08-10-2013, 02:11 AM
Dimis's Avatar
What are you planing on cooking up there...?
I believe TWM does a custom cross ram intake.
At least that's what they told me when I was lookin into it for my car.
I went away from it for 2 reasons.
1) it would render the hood scoop functionally useless.
2) it cost more than selling my kidney.
The above reasons may or may not mater to you.
In which case it would look totally bad ass!!!
Old 08-10-2013, 03:47 AM
Default Couple of choices for this
Craig I was looking for a cross ram myself and got some very limited info. 8-12 manifolds in your picture where made. That is all. They where tunnel ports. Rumor has it that there where a couple of HR ones. No MR ones. Wayne J. passed away about a year ago and had 1 tunnel port. I talked to him about the possiblity of making a copy to build a case. He said that a 5 grand deposit to start and he wanted a couple of manifolds free. I don't have deep pockets for this deal. Wayne was a good man and had just gotted screwed over buying a couple of crate cammer motors.
I couple of guys have used the crossram manifold with out the distributor extension housing and gone to FI. Everything is under the top and uses to throttlebodies. the injector are mounted into the runners. This is not a bad manifold but needs some work for flow. We have a guy here, Joe Craine who will fix the flow problems and help equal out the cfm to each cylinder.
I have not heard of TWM making a crossram for an FE motor. I know MOON makes a SB and well as Keisler for SB and BB. There might be something with using a setup like the old PSE manifolds and again modifing this to work. Jay Brown on FE POWER would be the one to talk to.
You can get a weber kit for side mounting on a carb base intake. Good luck Rick L.
Old 08-10-2013, 06:08 AM
750hp's Avatar
If I don't sell the Arntz soon, the only reasonable next step is to fit an FE big block and some new side pipes. The engine set back in the Arntz would make it easier to have a cross ram than the 10 degree ITB setup.
From your two issues, #1 is no biggie, but #2 is
Craig
Old 08-10-2013, 06:28 AM
750hp's Avatar
Thanks Rick. I wish I liked the look of the dual carb cross ram manifolds because they're much easier to find! I wonder if the only option might be Hogan's or Marcella for a sheet metal intake?
Originally Posted by RICK LAKE View Post
couple of guys have used the crossram manifold with out the distributor extension housing and gone to FI. Everything is under the top and uses to throttlebodies. the injector are mounted into the runners. This is not a bad manifold but needs some work for flow. Good luck Rick L.
leroy17 likes this.
Craig
Old 08-10-2013, 06:30 AM
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
Visner Engine Development fabricated a 427 FE cross ram intake manifold for me, with Imagine Injection throttle bodies.
Similar in appearance to the Can Am manifold setup.
Drink no wine before its time
Old 08-10-2013, 01:16 PM
CC Member / Sponsor
The picture is of an Algon unit. They occasional pop up on ebay. There is a medium riser one on E-bay now.
Ford 427 Side Oiler Algon Fuel Injection Medium Riser 428 Cobra Jet | eBay
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 08-10-2013, 01:37 PM
CC Member / Sponsor
I do not know anything about it, but on Wikipedia.
File:Wiki 4 TunnelPort crossram efi.jpg - Wikipedia, the free encyclopedia
http://upload.wikimedia.org/wikipedi...horizontal.jpg
Cubic Performance
HiTech Legends
Evolve Lubricants
Old 08-10-2013, 08:19 PM
Default Could put one together using parts from modern engines
BXR efi crossram on a 351C adapter for a FE:
Someone in Australia is making crossrams like the one shown in this thread's first post for the 351C, which would fit on an FE adapter like the one used above. $3,500 if I remember right.
Old 08-12-2013, 02:25 AM
750hp's Avatar
Thanks for the links, Tom. That Algon unit looks to be in great condition, but the price is a worry.
Dumpling; wow I didn't even know about the 351C to FE adapters. I did some searching and see that Jay Brown is making these shortly. The port mismatch is pretty radical, however testing showed that it wasn't a huge issue. Jay is also planning to sell the base with the regular FE port shape, so that could be the perfect starting point for mounting some throttle bodies. I'll keep an eye out for this piece from Jay in the near future.
Thanks!
Craig
Old 08-12-2013, 03:42 AM
Dimis's Avatar
Craig, if your looking for quality advise, information and parts like linkages, TBs and the like, you could do much worse than EFI Hardware in Mitcham Vic.
Throttle Bodies, EFI Fuel Pumps, EFI Regulators, Wolf 3D Engine Management Systems, EFI Hardware
Suffice to say I've been super impressed with them. YMMV.
Old 08-12-2013, 04:03 AM
OZCOBRA's Avatar
Lightbulb
And......MorrisonOZ/Other Manifolds
ERA 626 likes this.
Old 08-12-2013, 06:49 AM
750hp's Avatar
Here's Jay's intake adaptor. Imagine what a low profile setup you could make with this. Consider that the base plate is a window to allow lifter replacement without breaking into water or removing your distributor.
From here; FE Intake Adapter
Craig
Old 08-17-2013, 08:39 AM
Jay Brown is literally taking names and handing out numbers for his first batch...which is mostly spoken for at this point. Don't know when the next batch will be available, but most likely not until next year.
Just a heads up.
Old 08-18-2013, 09:21 PM
Dimis's Avatar
More Jay Brown stuff for your consideration.
FE Intake Adapters
Enjoy.
Old 08-18-2013, 09:25 PM
fordracing65's Avatar
It looks like an awesome setup hence the price...
PRIDEnJOY
Old 08-19-2013, 03:17 AM
Gaz64's Avatar
FE Intake Adapters
Enjoy.
For a casting, that is an absolute BEAUTIFUL piece of work.
Gary
Old 05-27-2019, 05:43 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Originally Posted by OZCOBRA View Post
Morrison Makes the best cross ram in the world. I am having one designed /made for my 496CI FE now.
Old 05-30-2019, 10:29 PM
Cobra Make, Engine: Berry Cobra ,Tremec 5 spd . 408 windsor , double A arm 9"rear
Hi Mr ERA , a friend and i both bought a Morrison crossrams from Steve and Lesley , both good looking manifolds , Mine a 351w and friends 302 , heres a link , be patient . https://youtu.be/b0GIYqNOlzU . cheers from NZ
ERA 626 likes this.
Old 05-31-2019, 12:39 AM
eschaider's Avatar
Verrrry nice looking cross ram!
Ed
