I am feeling much better this morning after giving this issue some thought. I havent decided exactly what I will do as of yet. As stated last night, my thoughts were to cut down middle and place metal brackets with some grade 8 bolts. I want to shy away from welding it permanently, just in case that thing ever has to come out.
On a side note, has anyone ever thought about recreating another dash panel that sat lower that would allow the steering shaft to hang lower, allowing gauges above steering? It was just a thought last night as I was pondering the idea of cutting the support frame. Not sure if gauges would even fit on left or right hand side of the steering shaft. Another concern would be the room available after that shaft is lowered to the drivers legs.
