My current throttle cable comes out of the left foot well and routes to the front of the SB302 down the right side to the rear around to the left side and forward to connect to the 600CFM Holley carb. I'm not sure what the length is or where it came from but it has the ball receptacles at both ends. It works. My manual suggests using Ford OEM C8UZ9A758A throttle cable. That one measures 39". At 39" that would make the routing from the foot well to the carb an S curve. Is this S curve routing common to these cars? Looking at the Lokar cables, the common lengths are 24" and 36". Longer lengths available and needed end receptacles and brackets are extra. Because the foot well end is even with the carb, how are others routing their throttle cables? Thank You. Harry
