You want to connect the starter switch to the remote solenoid mounted at the rear engine compartment. One lead from switch goes to the HEAVY BAT cable that comes from the BAT + from the trunk mounted battery. The other lead will connect to the small terminal on the solenoid that will energize the relay and close the solenoid contacts. This will allow you to turn the motor over and adjust the valves.
