Dave,
I got it a couple of weeks ago. It's installed and I had to get a new belt for my alternator. I have yet to run my engine since I've modified my system. New WP, Modified water plumbing. I'm working on little stuff like trimming the posts on my hood and trunk latches, trunk props to come in hopefully today. Trunk License plate light wiring. I pulled my front wheel to check the brake mounts. What broke on yours? I was looking to replace the brake calipers and rotors, but I'm going to do that later unless I can see that there is going to be an immediate problem with them. Did you do anything to your rear brakes? I see that these calipers are mounted to a bracket welded to the rear end axel housing. Wilwoods mount to the axel housing flange.
