Social Groups
Cobra Manufacturer Groups
West Coast Owners Group
Raise Roll Bar
User Name
Remember Me?
Password
Portal
Register
FAQ
Community
For Sale
Gallery
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Contacts
Members List
Search Forums
Show Threads
Show Posts
Tag Search
Advanced Search
Go to Page...
Portal
Forums
Active Topics
Advertising Rates
Journal
March 2025
S
M
T
W
T
F
S
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
Superformance
Finish Line
Hurricane Motorsports
Serpent Express
Planet Cobra
Shell Valley Classic Wheels
Eight Stack Injection
Raise Roll Bar
Discussion Tools
07-16-2014
11:35 AM
permalink
cycleguy55
My roll bar is currently at the higher of the two positions, and I'd like to raise it further - about 3" higher.
It seems to me I could get a stepped sleeve where the lower diameter would fit into and bolt to the roll bar, while the lower portion would be the same diameter as the roll bar (2 1/2") and fit into and bolt to the roll bar mounting sockets on the frame. I haven't measured yet, but it seems I could get 3" higher without the upper bolt holes on the roll bar being exposed above the body.
Anybody do anything like this?
07-16-2014
03:42 PM
permalink
PAINTER
Why so high
you don't want it above the windshield
raise it more than 2 in the bar pocket would have to be reinforced
John
07-16-2014
07:41 PM
permalink
cycleguy55
FWIW, the bottom of the roll bar is 4" above the highest point of the body immediately beneath it. I just put a level from the top of the windshield in the centre of the car to the top of the roll bar, and the roll bar is 2.75" below the top of the windshield (in the centre). Finally, the bolts fastening the roll bar to the frame sockets are in the upper holes.
What I'm suggesting with a stepped sleeve would reinforce the roll bar though, of course, it would do nothing to reinforce the sockets. Perhaps I don't need to raise it 3", but raising it 2.75" would only get it even with the top of the windshield.
I'd probably leave well enough alone if mine was at the height yours is, as it certainly appears higher than mine when I look at pictures of your car. Also, when I look at yours it seems you have a few inches of straight tubing before the start of the curve, whereas mine starts to bend not very far above the top of the grommet.
07-27-2014
08:25 PM
permalink
cycleguy55
John:
I don't know about the roll bar on your car, but I pulled my roll bar today, and the I.D. was slightly over 2 5/16", meaning the wall thickness is somewhere around 0.080 - 0.090". To be blunt, it doesn't appear to me to be much thicker than normal exhaust tubing (usually 0.065").
Based on the above, it would seem the roll bar is more for decoration than something we should depend upon too greatly. As to the sockets / bar pockets, they're far more robust than my roll bar, and I suspect if push came to shove the roll bar would bend or collapse and the sockets would be just fine.
Just my $0.02.
08-15-2014
09:41 AM
permalink
cycleguy55
I have raised my roll bar 2.5", and the top of it sits slightly above the head rests (Honda Civic Del Sol seats), but slightly below the top of the windshield. Looks much better.
08-15-2014
11:12 AM
permalink
Xack
Send photos of your roll bar installation/modification and of your seats... please.
Thanks,
Xack
08-18-2014
01:48 PM
permalink
cycleguy55
Original height - as I purchased it:
Raised Roll Bar:
Civic Del Sol seats:
Seats, shot through windshield:
08-20-2014
01:00 PM
permalink
Xack
It looks like someone cut your roll bar down to make it a kind of accent vs. something that works. Mine looks very much like your "after", but it may be slightly lower. YOu can check out my gallery photos
08-20-2014
02:56 PM
permalink
cycleguy55
FWiW, the bottom of the roll bar is now 6.5" above the highest point of the body immediately beneath it - it was 4" when I started. I looked at your photos and it seems mine might be slightly higher, perhaps an inch.
BTW, how big is that gas tank of yours? What are the dimensions? I like your cardboard template idea - I'll have to do that. I'm looking at having a tank made up by a local fabrication shop for more capacity and to reclaim some trunk space.
The previous owner installed a vertical tank in mine that's all of 12 gallons, and the forward face of it is about 3" aft of the vertical wall in the trunk (not the upper section), so it really chews up what little trunk space these cars have.
08-20-2014
06:29 PM
permalink
Xack
21 Gallons. I was thought I could make it larger than 21 gallons as well, but I had to cut back on the width because the shape makes it difficult to get into the trunk if it's any bigger in any dimension. It has tabs which you need to negotiate on entry. It's aluminum and coated with epoxy paint. I made a cardboard mock-up and made a drawing from that. I think this tank strikes a good balance and gives me the extended range I was looking for. If you want I have an isometric drawing with dimensions I sent to the tank manufacturer. This tank has 2 baffles side to side, and a baffle on the filler to prevent surges up and out of the filler lid.
Page 1 of 2
Discussion Tools
Mark This Discussion Read
02:49 PM
Contact Us
Club Cobra Home
Archive
Top
vBSEO
3.6.0
CC Policy
Links monetized by
VigLink
