I really like it, it takes a while to learn all the adjustments, but I like it. I am using timing control and the key is setting up your initial timing correctly. I set mine at 10 dbtdc and then locked out the distributor and did the spark advance curve from there. I like the fact I can advance idle to 18 and yet it still hot starts! I did not use the phased rotor but it is recommended. Timing Sync at 2000 and 4000 rpm is important.
